halui default spindle speed
- dangu85
29 Sep 2019 13:58 #146613
by dangu85
halui default spindle speed was created by dangu85
Hi. I found that setting the parameter spindle_speed_default in the *.ini file does not work correctly with the halui spindle commands.
If spindle is started from axis it starts spinning at set value, but if it's turned on from halui commands through glade buttons, the starting default speed is always 1.
Is there a way to use spindle_speed_default with glade/halui??
- Thank you received: 2181
29 Sep 2019 14:40 #146618
Replied by cmorley on topic halui default spindle speed
HALUI does not read the INI for default spindle speed.
With GladeVCP you can add python code to read the INI file to do most anything you want.
Chis
Chis
