MPG Jog Wheel
- billnixon
03 Oct 2019 15:29 #147027
by billnixon
MPG Jog Wheel was created by billnixon
I'm trying to get a basic 1 axis jog wheel to work as a proof of concept, but it's not working yet. Here is the little section of hal:
# --- MPG Jog X ---
setp axis.x.jog-vel-mode 0
setp axis.x.jog-scale .01
net x-jog-enable hm2_5i25.0.7i73.0.1.input-22-not => axis.x.jog-enable
net mpg-counts hm2_5i25.0.7i73.0.1.enc0.count => axis.x.jog-counts
The jog enable is just through a switch for testing purposes.
According to hal meters:
The switch output does not make it to axis.x.jog-enable.
The enc0.counts does not make it to axis.x.jog-counts.
The machine is homed before testing.
Any ideas what I can test?
# --- MPG Jog X ---
03 Oct 2019 23:24 #147089
Replied by andypugh on topic MPG Jog Wheel
Does the halmeter show the 7i73 pin values changing?
If it does then it suggests that your HAL code is not actually being executed.
- pl7i92
- Thank you received: 359
04 Oct 2019 05:34 #147106
by pl7i92
Replied by pl7i92 on topic MPG Jog Wheel
some more infos woudt be good what version of liuxcnc are you using
what OS
did you try the halui version in a postgui file
what OS
- billnixon
04 Oct 2019 13:07 #147126
by billnixon
Replied by billnixon on topic MPG Jog Wheel
Andy was right about the hal file. I was referencing the wrong file.
With the correct hal file, axis.x.jog-count does change with the encoder, but the axis still does not move. I am running version 2.8 on Mint 19 with the preempt kernel.
Here is a snippet from the hal:
####### MPG #######
# --- MPG Jog X ---
setp axis.x.jog-vel-mode 1
net x-jog-enable hm2_5i25.0.7i73.0.1.input-20-not => axis.x.jog-enable
net mpg-counts => axis.x.jog-counts
####### Rapid Override #######
net rapid-override-enable hm2_5i25.0.7i73.0.1.input-22-not => halui.rapid-override.count-enable
net mpg-counts => halui.rapid-override.counts
Using the mpg to change the rapid override works.
Here is another clue: jogging via a button works with halui.joint.0.plus, but not with halui.axis.x.plus.
I have not tried putting the jogging hal in the poustgui hal file. How do I determine what to put in the postgui file?
####### MPG #######
# --- MPG Jog X ---
- billnixon
06 Oct 2019 09:44 #147248
by billnixon
Update:
Jogging via a jog button works with halui.joint.0.plus while unhomed, but not while homed.
Jogging via a jog button works with halui.axis.x.plus while homed, but not while unhomed.
The mpg action is similar. It works with joint.0.jog-counts while unhomed, but not while homed. It works with axis.x.jog-counts while homed, but not while unhomed.
So the jogging works with joints unhomed, but not while homed. Is this normal, or do I still have a problem?
- newbynobi
- Thank you received: 394
07 Oct 2019 14:25 #147362
by newbynobi
Replied by newbynobi on topic MPG Jog Wheel
Prior to homing you will need to jog joints, not axis!
Check if the machine moves after homing using the mpg
- billnixon
07 Oct 2019 21:19 #147409
by billnixon
Yes, the machine moves after homing using the mpg when I connect the mpg to axis.x.jog-counts.
Would it be advisable to connect the jog buttons to both axis and joint like the following example using the x axis, so they would work before and after homing?
net jog-x-pos => halui.joint.0.plus halui.axis.x.plus
If this is okay, the jogging should be good to go.
- dgarrett
- Thank you received: 297
07 Oct 2019 21:56 #147412
by dgarrett
Advisable for trivkins kinematics for branches 2.8 and
after
Ref: linuxcnc.org/docs/2.8/html/getting-start...dating-linuxcnc.html
Halui jogging:
linuxcnc.org/docs/2.8/html/getting-start...linuxcnc.html#_halui
Wheel (MPG) jogging:
linuxcnc.org/docs/2.8/html/getting-start...se_generator_jogging
Replied by dgarrett on topic MPG Jog Wheel
net jog-x-pos => halui.joint.0.plus halui.axis.x.plusAdvisable for trivkins kinematics for branches 2.8 and
after
Halui jogging:
- billnixon
08 Oct 2019 07:00 #147454
by billnixon
Thanks for the help
