what is the right command(sequence) for adding new tool?
7 years 5 days ago #148884 by Reinhard
I'm able to manage changes of existing tools yet, but I had no success on adding a new tool to list.
Andypugh told me to treat tool-table-file as readonly, which works for minor administration changes.
I looked at the NML classes containing tool in name, but none of them sounded appropriate ...
... and most of them have no parameters.
Any hint is appreciated
7 years 3 days ago #149024 by HueyHQ
I'm not sure if I misunderstand the question, but tool.tbl is certainly editable, which is the way I initially setup my tools.
Alternatively, you can add tools using File -> Edit Tool Table, from memory.
7 years 3 days ago #149025 by Reinhard
... but tool.tbl is certainly editable, which is the way I initially setup my tools.
Well, I know, that the file is editable - and you probabely restart linuxcnc after changing the file (outside of linuxcnc).
I'm working on an UI, that enables the user do all the tasks as with a professional mill.
After andypugh told me, that I should treat the file as readonly, I did some tests.
Linuxcnc (one of the background processes) reads the tool table file and NML-status structure reflects the tool table.
Changes to tool offsets are sent from the UI to linuxcnc and on shutdown linuxcnc writes the changes to that file.
Then I found out, that linuxcnc status structure can hold about 50 tools and I thought, what if you have a big tool changer for that 50 tools but have more tools than you can place in the toolchanger.
Then you need a way to put tools in and pull others out (for me tool table file holds the tools inside atc).
Physically no problem - respect to data this should be possible during runtime of linuxcnc.
For me its no problem to change tool-table file. But then I need a way to tell linuxcnc that the file has changed and need to be imported again.
Shuting linuxcnc down and restarting it again sounds quite unprofessional to me, so I look for another way.
May be someone has already done that and can shine me a light?
7 years 3 days ago #149026 by phillc54
You can reload the tool table from within tooledit. linuxcnc.org/docs/html/gui/tooledit.html
7 years 3 days ago #149027 by HueyHQ
HueyHQ wrote: I'm not sure if I misunderstand the question...
Yup, totally misunderstood the question! ;)
7 years 3 days ago #149060 by Reinhard
Hi Phil,
thank you for that hint. I skipped tooleditor completely :(
As usual with axis, information is pretty obfuscated - but after all I found the command.
Yes, I overseen it too.
Will try it soon.
Thank you for your attention anyway!
Cheers Reinhard
Time to create page: 0.478 seconds
