what is the right command(sequence) for adding new tool?
- Reinhard
- Thank you received: 94
27 Oct 2019 14:43 #148884
by Reinhard
what is the right command(sequence) for adding new tool? was created by Reinhard
I'm able to manage changes of existing tools yet, but I had no success on adding a new tool to list.
Andypugh told me to treat tool-table-file as readonly, which works for minor administration changes.
I looked at the NML classes containing tool in name, but none of them sounded appropriate ...
... and most of them have no parameters.
Any hint is appreciated
- HueyHQ
- Thank you received: 24
29 Oct 2019 00:06 #149024
by HueyHQ
Replied by HueyHQ on topic what is the right command(sequence) for adding new tool?
I'm not sure if I misunderstand the question, but tool.tbl is certainly editable, which is the way I initially setup my tools.
Alternatively, you can add tools using File -> Edit Tool Table, from memory.
- Reinhard
29 Oct 2019 03:32 #149025
by Reinhard
I'm working on an UI, that enables the user do all the tasks as with a professional mill.
After andypugh told me, that I should treat the file as readonly, I did some tests.
Linuxcnc (one of the background processes) reads the tool table file and NML-status structure reflects the tool table.
Changes to tool offsets are sent from the UI to linuxcnc and on shutdown linuxcnc writes the changes to that file.
Then I found out, that linuxcnc status structure can hold about 50 tools and I thought, what if you have a big tool changer for that 50 tools but have more tools than you can place in the toolchanger.
Then you need a way to put tools in and pull others out (for me tool table file holds the tools inside atc).
Physically no problem - respect to data this should be possible during runtime of linuxcnc.
For me its no problem to change tool-table file. But then I need a way to tell linuxcnc that the file has changed and need to be imported again.
Shuting linuxcnc down and restarting it again sounds quite unprofessional to me, so I look for another way.
May be someone has already done that and can shine me a light?
Replied by Reinhard on topic what is the right command(sequence) for adding new tool?
Well, I know, that the file is editable - and you probabely restart linuxcnc after changing the file (outside of linuxcnc).... but tool.tbl is certainly editable, which is the way I initially setup my tools.
- phillc54
- Thank you received: 2100
29 Oct 2019 05:51 #149026
by phillc54
Replied by phillc54 on topic what is the right command(sequence) for adding new tool?
You can reload the tool table from within tooledit. linuxcnc.org/docs/html/gui/tooledit.html
- HueyHQ
29 Oct 2019 06:22 #149027
by HueyHQ
Yup, totally misunderstood the question!I'm not sure if I misunderstand the question...
- Reinhard
29 Oct 2019 15:52 #149060
by Reinhard
Hi Phil,
thank you for that hint. I skipped tooleditor completely
As usual with axis, information is pretty obfuscated - but after all I found the command.
Yes, I overseen it too.
Will try it soon.
Cheers Reinhard
Will try it soon.
Thank you for your attention anyway!Yup, totally misunderstood the question!
Cheers Reinhard
- Reinhard
31 Oct 2019 03:47 #149257
by Reinhard
I was able to do a quick test. Good news: it works.
Then I tested the "reload" of a complete different file. This worked too, but had the side effect, that the original tool table was overwritten with the content of the other file. That was unwanted.
So bug or feature?
I'd like the idea of loading different tool-table sets. But I'd like to preserve each file - same as with gcode files. So what about adding path of tool-table-file to Tool-stats and change persistence handling with a given new filename?
So bug or feature?
- phillc54
01 Nov 2019 07:23 #149334
by phillc54
You could have four tool tables, say tools.0, tools.1, tools.2 and tools.1
tools.0 would be empty and it would be the one you specified in your .ini file
tools.1, tools.2 & tools.3 would be your real tool table sets
Create (or add to an existing) a GladeVCP panel with three buttons to load the tool tables
In the python handler file for each button have something like:
This would load the contents of tools.1 into the current tool table (tools.0) as the startup tool table
You wouldn't be able to edit tools.1, tools.2 or tools.3 from the GUI as it would only edit the current contents of tools.0
Warning: Spoiler!
#!/usr/bin/env python
import os
import linuxcnc
import shutil
def tools(new):
shutil.copy(new, table)
c.load_tool_table()
def on_tools_1_clicked(widget):
tools('tools.1')
def on_tools_2_clicked(widget):
tools('tools.2')
def on_tools_3_clicked(widget):
tools('tools.3')
i = linuxcnc.ini(os.environ['INI_FILE_NAME'])
c = linuxcnc.command()
table = i.find('EMCIO', 'TOOL_TABLE')
tools('tools.1')This would load the contents of tools.1 into the current tool table (tools.0) as the startup tool table
- Reinhard
01 Nov 2019 09:07 #149342
by Reinhard
Hi Phil,
I kept thinking about tool management too and I finally came to the conclusion, that my conception of tool management is not appropriate for a cnc machine/controller.
So I probabely will create a standalone tooleditor with hierarchical tool definitions and lots of properties, so that you can share your tool definitions between cam and cnc-machine.
Then I will enable the tooleditor to generate a tool table file for linuxcnc (and another for a cam) and then a reload-button in the UI (together with single file handling) will suffice.
Thanks anyway
Thanks anyway
- Thank you received: 4654
04 Nov 2019 13:17 #149545
It probably is. But LinuxCNC itself is far too simplistic in its tool handling.
Some time ago I came up with this, and even got some way in to making LinuxCNC work that way:
wiki.linuxcnc.org/cgi-bin/wiki.pl?ToolDatabase
Replied by andypugh on topic what is the right command(sequence) for adding new tool?
Time to create page: 0.462 seconds
