Inverting an output pin
- Elco
- Thank you received: 3
06 Nov 2019 15:54 #149730
by Elco
Inverting an output pin was created by Elco
How does one invert an output signal? The manual mentions this:
• parport.<p>.pin-<n>-out-invert (bit) Inverts an output pin.
Original HAL file attached.
However, when I change my hal file accordingly, Linuxcnc crashes with the following error (Kernel bit deleted):
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0-pre1-5212-g8da4d21ad
Machine configuration directory is '/home/robert/linuxcnc/configs/cnc_3'
Machine configuration file is 'cnc_3.ini'
INIFILE=/home/robert/linuxcnc/configs/cnc_3/cnc_3.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./cnc_3.hal
config string '0 x'
Debug file information:
Note: Using POSIX realtime
./cnc_3.hal:53: Pin 'parport.0.pin-08-out-invert' does not exist
1432
Stopping realtime threads
Unloading hal components
Kernel message information:
[rest deleted]
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=1.1
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z
config string '0 x'
1432
[rest deleted]
- toplakd
- Thank you received: 7
06 Nov 2019 16:09 #149731
by toplakd
Replied by toplakd on topic Inverting an output pin
This is hove my inverted input looks:
net z-home-s <= hm2_7i92.0.gpio.030.in_not
So I assume for output pin could be same
out_not or out-not
out_not or out-not
- Elco
06 Nov 2019 16:33 #149732
by Elco
Replied by Elco on topic Inverting an output pin
Is there anywhere in the manual where that is described?
I could imagine using the not function in two steps:
net xenable => not.0.in
not.0.out => parport.0.pin-08-out
(If that is the correct syntax)
And I assume this (manual 11.1.4) is incorrect:
- toplakd
06 Nov 2019 16:40 - 06 Nov 2019 16:44 #149733
by toplakd
I would try it same way as you have inverted your estop, with -not at the end.
net estop-ext <= parport.0.pin-15-in-not
Last edit: 06 Nov 2019 16:44 by toplakd.
- Thank you received: 1476
06 Nov 2019 18:52 - 06 Nov 2019 18:53 #149743
Replied by Todd Zuercher on topic Inverting an output pin
parport.N.pin-xx-out-invert is a parameter not a pin and you use a setp command to set it.
The way to invert a parallel port output is like this. Then you connect the out pin as normal.
setp parport.0.pin-08-out-invert true
net xenable => parport.0.pin-08-out
Last edit: 06 Nov 2019 18:53 by Todd Zuercher.
The following user(s) said Thank You: Elco, millathe
Time to create page: 0.252 seconds
