get relative commanded position from a hal pin
08 Nov 2019 20:36 #149958 by ftkalcevic
Is there any way to get the relative commanded position for an axis from a hal pin? Or offsets?
I'm trying to feed the commanded x position into the eoffset_per_angle.radius-ref so I can use non-circular turning by just adjusting the x position (radius/diameter)
I can get it to work using axis.x.pos-cmd, but this is absolute position - it doesn't include coordinate or tool offsets.
Ideally I just need the coordinate and tool offsets so I can add that to the absolute commanded position which doesn't include the external offset.
09 Nov 2019 02:15 #149965 by pl7i92
hi
this will get you the command directly
#<_x> - Return current relative X coordinate including all offsets. Same as #5420.
09 Nov 2019 02:48 #149971 by fixer
You can get tooloffsets and absolute position from "motion" hal module. Work offsets are a bit tricky, it possible to get values with python interface, but that is not realtime and you will bump into problems with read-ahead. Python interface gives you current interpreter state, it always returns G54 as current modal state.
10 Nov 2019 23:44 #150083 by ftkalcevic
Replied by ftkalcevic on topic get relative commanded position from a hal pin
Thanks for the suggestions.
I ended up adding g5x_offset and g92_offset to halui for my needs. It isn't real time, but most of the time I'm just turning multiple reducing radii.
12 Nov 2019 06:59 #150191 by andypugh
Replied by andypugh on topic get relative commanded position from a hal pin
You probably don't need the tool and coordinate offsets in realtime, they don't normally change during a cut.
So your offsetting component should be able to make use of halui.axis.L.pos−relative at the beginning of the cycle to calculate a total offset and then keep that as in internal constant.
Time to create page: 0.176 seconds
