ShuttleXpress HAL file modification.
  • Rick_Jeff_2019
  • Topic Author
  • New Member
  • New Member
6 years 11 months ago #151381 by Rick_Jeff_2019
ShuttleXpress HAL file modification. was created by Rick_Jeff_2019
A HAL file to support the ShuttleXpress USB Dongle was obtained from the following source:
github.com/araisrobo/linuxcnc/blob/maste...on/shuttlexpress.hal
While this code worked just fine, we found it inconvenient to have to hold down and x, y, or z button while jogging a particular axis. Instead, we preferred that the x,y, or z button need only be tapped, after which the axis could be jogged. (This functionality is consistent with that used by Tormach Inc. on its Pathpilot interface.)
The following code uses the D Flip Flop HAL command to make the x, y, or z key press persistent. It is based on a modification of the code obtained from the link above. The new code is found in the attachment. Note that we also modified the parameters for the jog speed to suit our machine. The former values are retained as comments.
The following user(s) said Thank You: Haarie
6 years 11 months ago #151411 by pl7i92
Replied by pl7i92 on topic ShuttleXpress HAL file modification.
thank yoiu
this may be good for handworker 's
but break alot of bits and mashine component on non PRO users
as the communication may brak and the mashine is running wild
6 years 11 months ago #151425 by Todd Zuercher
Replied by Todd Zuercher on topic ShuttleXpress HAL file modification.
I don't think he is using this on the jog button, just the axis select button.
Time to create page: 0.053 seconds
