5i25 7i77 .hal configuration
6 years 10 months ago #152731 by slckzbn
I tried set 5i25 and 7i77 boards .hal file but i get './7i77.hal:43: Pin 'hm2_5i25.0.7i77.0.1.analogena' error.
When I delete the error code that enables hm2_5i25.0 he found other errors cause and began what could be the solution?
mesaflash --device 5i25 --readhmid /command result file in attachments.
File Name: result_2019-12-16.txt
File Size:4.15 KB
File Name: 7i77.hal
File Size:3.35 KB
File Name: HM2-Servo.ini
File Size:4.38 KB
6 years 10 months ago #152733 by bevins
Replied by bevins on topic 5i25 7i77 .hal configuration
slckzbn wrote: I tried set 5i25 and 7i77 boards .hal file but i get './7i77.hal:43: Pin 'hm2_5i25.0.7i77.0.1.analogena' error.
File Size:4.15 KB
File Name: 7i77.hal
File Size:3.35 KB
File Size:4.38 KB
Add field power to the 7i77 and make sure you have 5 volts either by using the power from 5i25 or applying 5v to terminal on 7i77 after setting jumpers.
The following user(s) said Thank You: slckzbn
6 years 10 months ago #152735 by tommylight
Did you provide power to the 7i77 ?
It needs +5V for the analogue side and 8-28V for the VField.
6 years 10 months ago #152842 by slckzbn
i solved the problem but now i got 'joint following error'.How can i solve this problem ?
File Name: 5i25-7i77.ini
File Size:4.38 KB
File Name: 7i77_2019-12-18.hal
File Size:3.36 KB
6 years 10 months ago - 6 years 10 months ago #152846 by PCW
Replied by PCW on topic 5i25 7i77 .hal configuration
Following errors are expected initially, here is a basic velocity mode servo tuning tutorial:
gnipsel.com/linuxcnc/tuning/servo.html
Last edit: 6 years 10 months ago by PCW.
Time to create page: 0.332 seconds
