Gearchange comp. - Problem with spindle speed
30 Dec 2019 06:39 #153548 by Cynas
Hello, I'm trying to run a gear change using the component
component gearchangefadal "A component to choose spindle gears according to spindle speed";
pin in float speed-command;
pin in bit spindle-on;
pin in bit manual-low;
pin in bit manual-high;
pin in bit brake-enable;
pin out float motor-speed;
pin out bit low-gear;
pin out bit high-gear;
pin out bit brake;
param rw float low-ratio=3;
param rw float high-ratio=1;
param rw float max-low = 50;
author "andy pugh";
license "GPL";
function _;
FUNCTION(_){
    static int old_M3;
    if (spindle_on) {
        if (!old_M3){ // spindle off to on transition
            if (manual_high) {
                high_gear = 1;
                low_gear = 0;
                brake = 0;
            else if (manual_low){
                high_gear = 0;
                low_gear = 1;
                brake = 0;
            } else if (speed_command <= max_low){
                high_gear = 0;
                low_gear = 1;
                brake = 0;
            } else {
                high_gear = 1;
                low_gear = 0;
                brake = 0;
    } else { //spindle off
        brake = brake_enable;
    old_M3 = spindle_on;
    if (high_gear){
        motor_speed = speed_command * high_ratio;
    } else if (low_gear){
        motor_speed = speed_command * low_ratio;
everything works fine if it uses:
net spindle-vel-cmd-rpm-abs => gearchange.0.speed-command
however, the value changes when I use the spindle speed potentiometer, and this is incorrect for me.
I found a constant value for the spindle speed
net spindle-speed-cmd-rps <= motion.spindle-speed-cmd-rps
net spindle-speed-cmd-rps =>  gearchange.0.speed-command
unfortunately the gearbox doesn't want to work properly. The spindle always starts in low gear despite the fact that the HAL METER values are correct and visible.
I also tried to use the converter with float-> s32 and s32-> float
Anyone know why this is happening ??
Is there another signal that would be helpful to me?
Thank you for your help
30 Dec 2019 09:14 #153551 by PCW
Can you post your hal file?
The following user(s) said Thank You: Cynas
31 Dec 2019 10:56 #153615 by Cynas
Thank you for your interest
I solved the problem. I don't know why when I was sending the ABS value to the component it did not work properly.
I am using now:
net spindle-speed-cmd-rps => gearchangefadal.0.speed-command
and in the component I changed:
else if (speed_command >= (max_low)*(-1) && speed_command <= max_low){
                high_gear = 0;
                low_gear = 1;
                brake = 0;
I tried to add: else if ( absf ( speed_command ) <= max_low), but it displays an error, and I took shortcuts
best regards
ps: I will give it all, maybe someone will be useful
pin out bit brake;
author "andy pugh";
license "GPL";
function _;
FUNCTION(_){
    static int old_M3;
	float fabsf;
    if (spindle_on) {
            if (manual_high) {
                high_gear = 1;
                low_gear = 0;
                brake = 0;
                high_gear = 0;
                low_gear = 1;
                brake = 0;
            } else if (speed_command >= (max_low)*(-1) && speed_command <= max_low){
                high_gear = 0;
                low_gear = 1;
                brake = 0;
            } else {
                high_gear = 1;
                low_gear = 0;
                brake = 0;
    if (high_gear){
The following user(s) said Thank You: J Green
Time to create page: 0.159 seconds
