G33.1 - no position reset when index detects
- Cynas
- Thank you received: 3
04 Jan 2020 08:21 #153990
by Cynas
G33.1 - no position reset when index detects was created by Cynas
Hi, I'm trying to run rigid tapping g33.1 but I've found a problem.
All readings in Hal Meter and Hal Scope are only correct when starting the G33.1 cycle the position counter does not reset.
After starting G33.1, it waits for the index signal and receives it, and then quickly moves down the distance (position * thread pitch).
the index signal receives from the hall sensor
my hal:
my ini:
The same problem occurs when using g76
It looks like the Z movement is trying to catch up with the position of the spindle, which is being added all the time. After starting g33.1 it can still have a very high value.
Did I miss something in the configuration or maybe my thinking is wrong?
motion.spindle-revs increases by 1 for one spindle revolutionthe index signal receives from the hall sensor
my hal:
# SPINDLE S
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm-abs => pid.s.command
net spindle-vel-fb-rpm-abs => pid.s.feedback
net spindle-output <= pid.s.output
# ---digital potentionmeter output signals/setup---
setp hm2_7i76e.0.7i76.0.0.spinout-minlim [SPINDLE_9]OUTPUT_MIN_LIMIT
setp hm2_7i76e.0.7i76.0.0.spinout-maxlim [SPINDLE_9]OUTPUT_MAX_LIMIT
setp hm2_7i76e.0.7i76.0.0.spinout-scalemax [SPINDLE_9]OUTPUT_SCALE
net spindle-output => hm2_7i76e.0.7i76.0.0.spinout
#net spindle-enable => hm2_7i76e.0.7i76.0.0.spinena
net spindle-enable => or2.0.in0
net spindle-enable-oriented => or2.0.in1
net spindle-enable-or2.0 or2.0.out => timedelay.1.in
net opoznienie-spindle-enable timedelay.1.out => hm2_7i76e.0.7i76.0.0.spinena
net spindle-ccw => hm2_7i76e.0.7i76.0.0.spindir
#setp hm2_7i76e.0.encoder.00.counter-mode 0
setp hm2_7i76e.0.encoder.00.counter-mode 1
setp hm2_7i76e.0.encoder.00.filter 1
setp hm2_7i76e.0.encoder.00.index-invert 1
setp hm2_7i76e.0.encoder.00.index-mask 0
setp hm2_7i76e.0.encoder.00.index-mask-invert 0
setp hm2_7i76e.0.encoder.00.scale [SPINDLE_9]ENCODER_SCALE
net spindle-revs <= hm2_7i76e.0.encoder.00.position
net spindle-vel-fb-rps <= hm2_7i76e.0.encoder.00.velocity
#net spindle-index-enable <=> hm2_7i76e.0.encoder.00.index-enable
net spindle-speed-cmd-rps <= motion.spindle-speed-cmd-rps
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
#net spindle-index-enable <=> motion.spindle-index-enable
net spindle-index-enable encoder.0.index-enable <=> motion.spindle-index-enable
net spindle-index encoder.0.phase-Z
net spindle-index hm2_7i76e.0.7i76.0.0.input-12-not
net spindle-orient <= motion.spindle-orient
net spindle-is-oriented => motion.spindle-is-oriented
net spindle-locked <= motion.spindle-locked
sets spindle-at-speed truemy ini:
ENCODER_SCALE = -1000The same problem occurs when using g76
- Thank you received: 5337
04 Jan 2020 09:07 #153993
Replied by PCW on topic G33.1 - no position reset when index detects
For the hardware index to work, the index signal must connect to the encoder input on the 7I76E.
The following user(s) said Thank You: Cynas
- Cynas
04 Jan 2020 09:13 - 04 Jan 2020 09:23 #153995
by Cynas
Replied by Cynas on topic G33.1 - no position reset when index detects
How can I make such a connection in the hal ?
Last edit: 04 Jan 2020 09:23 by Cynas.
04 Jan 2020 09:20 #153996
It has to be done in hardware, not hal, that is, you must connect the index signal to the 7I76E's index input
This can be done in hal with a software encoder counter but a software encoder will not work well with a 1000 count/turn encoder
- Cynas
04 Jan 2020 09:23 #153997
by Cynas
If I use a 5V encoder for A, B signals. Can I connect a 24 V sensor output in place of the Index?
Do I have to use a transition system that converts 24V to 5V?
I don't see this information anywhere in manual 7i76E
04 Jan 2020 09:32 #153998
You would need to translate the voltage from the sensor to 5V
(voltages in excess of 12V will damage the 7I76E encoder inputs)
This translation could be done with an opto-coupler or similar device
- Cynas
04 Jan 2020 09:37 #153999
by Cynas
I will try to build such a system
Thank you
Thank you
- Cynas
04 Jan 2020 14:23 #154018
by Cynas
- Cynas
08 Jan 2020 09:11 #154312
by Cynas
One picture expresses more than 1000 words
- Clive S
- Thank you received: 486
08 Jan 2020 11:34 #154326
by Clive S
Replied by Clive S on topic G33.1 - no position reset when index detects
Very nice.
Would you mind posting your config files.
Time to create page: 0.131 seconds
