Comparisons in hal
  • RobotMatic
  • RobotMatic's Avatar Topic Author
  • Elite Member
  • Elite Member
11 Jan 2020 08:04 #154608 by RobotMatic
Comparisons in hal was created by RobotMatic
how can i do conditional type IF
Is this possible without ladder?
Thak you !
11 Jan 2020 08:17 #154610 by Mike_Eitel
Replied by Mike_Eitel on topic Comparisons in hal
AND2 if you have a digital signal.
11 Jan 2020 09:11 #154617 by Todd Zuercher
Replied by Todd Zuercher on topic Comparisons in hal
"Near" could be used to compare floats.
11 Jan 2020 09:26 #154619 by andypugh
Replied by andypugh on topic Comparisons in hal
or wcomp for nearly the same, bigger and smaller.
linuxcnc.org/docs/2.7/html/man/man9/wcomp.9.html
  • RobotMatic
  • Elite Member
  • Elite Member
11 Jan 2020 16:52 #154652 by RobotMatic
Replied by RobotMatic on topic Comparisons in hal
I understand now that I can't with hal. !
then it is better to use ladder and voila !!
I am using the encoder component as a counter on channel A.
I wanted to reset the counter to a defined count number
It's just an exercise I wanted to do
Thank you a lot
12 Jan 2020 07:44 #154670 by PCW
Replied by PCW on topic Comparisons in hal
Actually you can do this in hal with wcomp
(assuming you want to reset the counter at a given count)
You could also reset it to a given number by using counter reset
and the offset component
  • RobotMatic
  • Elite Member
  • Elite Member
12 Jan 2020 08:44 #154673 by RobotMatic
File Name: custom.hal
File Size:3 KB
I could reset! thanks!!
Now I will see if I can change the time-delay on-off times.
I am discovering a new world with HAl.
thannnkkk youuuu
Time to create page: 0.434 seconds
