Write Pin halui.rapid−override.value
27 Jan 2020 15:29 #155915 by chris@cnc
Write Pin halui.rapid−override.value was created by chris@cnc
Hi there,
I'm currently install a 4 bit rotary switch to regulate the rapid feed rate. But I don't want to go through a counter. The disadvantage is that I always have to switch to 100% after machine start and back until it counts correctly. My idea is to write the pin halui.rapid − override.value directly with the result from the mux register. But the error is
./my_LinuxCNC_machine.hal:98: Signal 'eilgang-incr' can not add OUT pin 'halui.rapid-override.value', it already has OUT pin 'eilgang.out-f'
Example now working:
setp halui.rapid-override.direct-value true
setp halui.rapid-override.scale 0.01
net eilgang-incr <= eilgang.out-s
net eilgang-incr => halui.rapid-override.counts
net eilgang-bit0 => eilgang.sel0
net eilgang-bit1 => eilgang.sel1
net eilgang-bit2 => eilgang.sel2
setp eilgang.debounce-time 0.200000
setp eilgang.use-graycode False
setp eilgang.suppress-no-input False
setp eilgang.in00 0
setp eilgang.in01 25
setp eilgang.in02 50
setp eilgang.in03 75
setp eilgang.in04 100
example whish:
net eilgang-incr <= eilgang.out-f
net eilgang-incr => halui.rapid-override.value
setp eilgang.in00 0
setp eilgang.in01 0.25
setp eilgang.in02 0.50
setp eilgang.in03 0.75
setp eilgang.in04 1
27 Jan 2020 15:36 #155917 by bbsr_5a
Replied by bbsr_5a on topic Write Pin halui.rapid−override.value
did you doe this in the postgui HAL file
then the interpreter accepts from outer world
the Postgui is detach from the startup
27 Jan 2020 15:52 #155924 by chris@cnc
Replied by chris@cnc on topic Write Pin halui.rapid−override.value
i try it but same message
custom_postgui.hal:10: Signal 'eilgang-incr' can not add OUT pin 'halui.rapid-override.value', it already has OUT pin 'eilgang.out-f'
It seems pin 'halui.rapid-override.value', is not writeable. OUT Pin only...?
27 Jan 2020 17:38 #155935 by Mike_Eitel
Replied by Mike_Eitel on topic Write Pin halui.rapid−override.value
Hi Chris
Can't remember exactly how i did with an analog potentiometer. But it is based on Norberts gui as he has that solution in his gmoccappy. Maybe you have a look into the gmoccapy examples
Mike
27 Jan 2020 20:10 #155944 by chris@cnc
hello mike, hello bbsr,
found it by accident. I created a new config and accidentally overwritten my test hal. So that it does not happen again, I wrote all changes in the postgui. Now it works with the counter. shortly after the start, the rapid traverse jumps to the set value. before that, it was always 100% after the start.
27 Jan 2020 20:26 #155950 by Mike_Eitel
Good, congrats
28 Jan 2020 10:51 #155986 by bbsr_5a
so the Error has only been to be configured in the wrong file ?
28 Jan 2020 17:59 #156031 by chris@cnc
That's how you can say it. The reason why I wanted to write the variable is that after machine start I have to turn the override so that it is displayed correctly. If you write the override section in the post gui, it will be corrected shortly after the start. I don't understand it but am happy that it works ...
Time to create page: 0.111 seconds
