7i47s Analog out
6 years 8 months ago #156983 by dremeier
7i47s Analog out was created by dremeier
Can someone give me an example for the analog out of the 7i47s, regarding for spindle control?
Is that a hardware PWM or need as software PWM? The Bit file is correct, I got it direct from Mesa. thx!
I tried a lot bus nothing works. Using l-cnc 2.9.
Any suggestions are welcome!
6 years 8 months ago #156984 by PCW
Replied by PCW on topic 7i47s Analog out
You would use hardware PWM set to about 5KHz
What bit file are you using?
6 years 8 months ago #156985 by dremeier
Replied by dremeier on topic 7i47s Analog out
attached the bit file and pin file.
for hardware pwm I should see these pins in HAL-Show, right? But there is only pwmgen.value and pwmgen.on.
How does the hardware PWM would look like in HAL?
6 years 8 months ago #156986 by PCW
pins should it should be something like
hm2_5i24.0.pwmgen.00.enable
and
hm2_5i24.0.pwmgen.00.value
and parameters
hm2_5i24.0.pwmgen.pwm_frequency
etc
6 years 8 months ago #156989 by dremeier
ok thank you, I got it, so far so good:
for testing I´ve this in the hal:
setp hm2_5i24.0.pwmgen.00.scale -100
setp hm2_5i24.0.pwmgen.00.output-type 1
setp hm2_5i24.0.pwmgen.00.enable TRUE
setp hm2_5i24.0.pwmgen.pwm_frequency 5000
setp hm2_5i24.0.pwmgen.00.offset-mode 0
setp hm2_5i24.0.pwmgen.00.value 20
But
if the value is 20 the voltage is 8V
if the value is 80 the voltage is 2V
but I guess it should be vice versa?
6 years 8 months ago #156990 by tommylight
Time to create page: 0.393 seconds
