7i47s Analog out
  • dremeier
  • dremeier's Avatar Topic Author
  • New Member
  • New Member
10 Feb 2020 15:40 #156983 by dremeier
7i47s Analog out was created by dremeier
Can someone give me an example for the analog out of the 7i47s, regarding for spindle control?
Is that a hardware PWM or need as software PWM? The Bit file is correct, I got it direct from Mesa. thx!
I tried a lot bus nothing works. Using l-cnc 2.9.
Any suggestions are welcome!
10 Feb 2020 15:55 #156984 by PCW
Replied by PCW on topic 7i47s Analog out
You would use hardware PWM set to about 5KHz
What bit file are you using?
  • dremeier
  • New Member
  • New Member
10 Feb 2020 16:22 #156985 by dremeier
Replied by dremeier on topic 7i47s Analog out
attached the bit file and pin file.
for hardware pwm I should see these pins in HAL-Show, right? But there is only pwmgen.value and pwmgen.on.
How does the hardware PWM would look like in HAL?
10 Feb 2020 16:49 #156986 by PCW
pins should it should be something like
hm2_5i24.0.pwmgen.00.enable
and
hm2_5i24.0.pwmgen.00.value
and parameters
hm2_5i24.0.pwmgen.pwm_frequency
etc
  • dremeier
  • New Member
  • New Member
10 Feb 2020 18:40 #156989 by dremeier
ok thank you, I got it, so far so good:
for testing I´ve this in the hal:
setp hm2_5i24.0.pwmgen.00.scale -100
setp hm2_5i24.0.pwmgen.00.output-type 1
setp hm2_5i24.0.pwmgen.00.enable TRUE
setp hm2_5i24.0.pwmgen.pwm_frequency 5000
setp hm2_5i24.0.pwmgen.00.offset-mode 0
setp hm2_5i24.0.pwmgen.00.value 20
But
if the value is 20 the voltage is 8V
if the value is 80 the voltage is 2V
but I guess it should be vice versa?
  • Moderator
  • Moderator
10 Feb 2020 18:55 #156990 by tommylight
Replied by tommylight on topic 7i47s Analog out
You have the scale reversed with " - " .
  • dremeier
  • New Member
  • New Member
10 Feb 2020 19:05 - 10 Feb 2020 19:12 #156994 by dremeier
yes, that was a try to revers the behavior but it is the same if the scale is +
Last edit: 10 Feb 2020 19:12 by dremeier.
10 Feb 2020 19:21 - 10 Feb 2020 19:22 #156996 by PCW
From the 7I78 manual:
"Spindle PWM is active low so if the 7I78 is used with HostMot2 firmware, the PWM output must be inverted."
on a 5I24 (and LinuxCNC 2.8 and above) you would:
setp hm2_5i24.0.pwmgen.00.out0.invert_output true
Last edit: 10 Feb 2020 19:22 by PCW.
  • dremeier
  • New Member
  • New Member
11 Feb 2020 03:42 #157032 by dremeier
ok, now I´ve it almost :-) !
here the HAL:
setp hm2_5i24.0.pwmgen.pwm_frequency [SPINDLE_0]PWM_FREQ
setp hm2_5i24.0.pwmgen.00.scale [SPINDLE_0]OUTPUT_SCALE
setp hm2_5i24.0.pwmgen.00.offset-mode 0 # 1 wenn value +- dann bei 0 = 50%
setp hm2_5i24.0.pwmgen.00.out0.invert_output true # damit der PWM Ausgang bei steigendem Value auch ansteigt
setp hm2_5i24.0.gpio.016.is_output 1 # gpio 016 ist Aux (M4) - auf Ausgang setzen
setp hm2_5i24.0.gpio.016.invert_output 1
net spindle-speed-cmd spindle.0.speed-out-abs => hm2_5i24.0.pwmgen.00.value
net spindle-on spindle.0.on => hm2_5i24.0.pwmgen.00.enable # FU und PWM enable
net spindle-fwd => spindle.0.forward => hm2_5i24.0.gpio.016.out # gpio 016 / Aux (M3)
net spindle-rev => spindle.0.reverse => hm2_5i24.0.7i90.0.0.p1-out-02 # M4 - da DIR nicht ansprechbar -> 7i90
Then I figured out that the markings for the optocoupler outs on the 7i47s (EN, DIR, AUX) are vice versa, + is - and - is +. But that does no matter for me.
The only thing I can´t figure out how to set the DIR output? Probably gpio.017 is for that purpose, but the only opportunity is to set the Parameter setp hm2_5i24.0.pwmgen.00.out1.invert_output to 0 to get a state change. This is not a pin so not possible to connect with 'net'. A out-pin related to gpio.017 I couldn´t find.
11 Feb 2020 06:29 #157041 by PCW
Depending on firmware, DIR will be controlled by the sign of the PWM rather than a GPIO bit
What is reversed about the Optocoupler outputs?
Time to create page: 0.153 seconds
