Parameters to classicladder possible?
- 3D-Master
- Thank you received: 5
14 Feb 2020 13:30 #157369
by 3D-Master
Parameters to classicladder possible? was created by 3D-Master
Hello,
i want to switch a "image bit" with the parameter for the rotation around the z axis in the current coordinate system but neither do i find this parameter nor do i think it is possible because these parameters have a rhombus (#) so linuxcnc would not read this line.
is there any hal pin for rotation around z in the current coordinate system?
how could this be done?
i thought about comparing the value of this parameter in classicladder and if it is 0 then it should not output a signal.
- Thank you received: 2181
14 Feb 2020 13:34 #157371
Replied by cmorley on topic Parameters to classicladder possible?
Can you restate what you want to do - assuming I don't know what you are talking of.
You need to know if the coordinate system is rotated via a HAL pin?
Chris
Chris
- 3D-Master
14 Feb 2020 14:53 #157376
by 3D-Master
Replied by 3D-Master on topic Parameters to classicladder possible?
at work we use Heidenhain controllers which lets you know if there is a rotation around the z axis by showing you a small icon. I want to create something similar for my machine. I have already implemented the "image bit" and can switch the images using halshow and setp.
for that to work automatically i need to use a pin which has the rotation value for the active coordinate system, which i can feed into classicladder.
it is just a small gimmicky bit i want to have but if it is not possible then it is okay (meaning it is not neccesary)
14 Feb 2020 18:34 #157392
Thanks for explaining again.
You can do this by building a python component that monitors linuxcnc's status of rotation_xy and then outputs the status on a HAL pin.
or if you already are using a gladevcp panel with a python handler file you could add the same idea there.
linuxcnc.org/docs/2.8/html/config/python...xcnc_stat_attributes
linuxcnc.org/docs/2.8/html/hal/halmodule.html
Chris
Chris
The following user(s) said Thank You: 3D-Master
14 Feb 2020 18:38 - 14 Feb 2020 18:38 #157393
If you are using 2.8+ Gstat has a 'current-z-rotation' message which may be somewhat easier to use.
you could probably adapt this sample:
linuxcnc.org/docs/2.8/html/gui/GStat.htm...mponent_code_pattern
Last edit: 14 Feb 2020 18:38 by cmorley.
- 3D-Master
15 Feb 2020 06:04 #157426
by 3D-Master
thank you, i will have a look at it
- 3D-Master
15 Feb 2020 07:52 - 15 Feb 2020 07:53 #157437
by 3D-Master
i have edited the example and i am 99% sure there is something wrong because i am a python noob:
do i need to "compile" the python file or can i just put it somewhere and call it via a M code? Then how is the newly created pin called? h.rotation_z.out?
btw i am using pyvcp, not gladevcp
#!/usr/bin/env python
import hal
from hal_glib import GStat
import gobject
GSTAT = GStat()
# callback to change HAL pin state
def mode_changed(obj, data):
h['rotation_xy'] = data
# Make a component and pins
h = hal.component("metric_status")
h.newpin("rotation_xy", hal.HAL_FLOAT, hal.HAL_OUT)
h.ready()
# connect a GSTAT message to a callback function
GSTAT.connect("metric-mode-changed",mode_changed)
# force GSTAT to initialize states
GSTAT.forced_update()
# loop till exit
try:
gobject.MainLoop().run()
except KeyboardInterrupt:
raise SystemExitdo i need to "compile" the python file or can i just put it somewhere and call it via a M code? Then how is the newly created pin called? h.rotation_z.out?
Last edit: 15 Feb 2020 07:53 by 3D-Master.
15 Feb 2020 08:23 - 15 Feb 2020 09:02 #157441
There are two pins; one for the angle, one for 'is-rotated' (bool pin)
The component will be called 'z_rotation'
Save the program as z_rotation.py in your config folder
load the component with 'loadusr python z_rotation.py'
Chris
import hal
import gobject
GSTAT = GStat()
# there is a current angle status pin and an is-rotated bool pin
def angle_changed(obj, data):
h['z-rotated-angle'] = data
if data == 0:
h['z-is-rotated'] = False
else:
h['z-is-rotated'] = True
h = hal.component("z_rotation")
h.newpin("z-rotated-angle", hal.HAL_FLOAT, hal.HAL_OUT)
h.newpin("z-is-rotated", hal.HAL_BIT, hal.HAL_OUT)
h.ready()
# connect a Z rotation message to the callback function
GSTAT.connect("current-z-rotation", angle_changed)
# loop till exit
try:
raise SystemExitThere are two pins; one for the angle, one for 'is-rotated' (bool pin)
Chris
Last edit: 15 Feb 2020 09:02 by cmorley.
- 3D-Master
15 Feb 2020 09:01 #157443
by 3D-Master
Thank you,
the component works like expected but when i want to connect the pin (halshow says the pin is named: z_rotation.z-rotated-angle)
i get an error saying the pin "z_rotation.z-rotated-angle" does not exist. i tried using ".out" and ".h" but it didnt work.
The component is loaded first and then the pin is being searched.
15 Feb 2020 09:10 #157446
sounds like a race condition.
How did you load the program and connect the pins - what file - you may need to use the -wn option to make HAL wait till the pins are made.
loadusr -Wn z_rotation python rotation.py
Chris
Chris
Time to create page: 1.032 seconds
