Parameters to classicladder possible?
- 3D-Master
- Thank you received: 5
15 Feb 2020 14:12 #157481
by 3D-Master
Replied by 3D-Master on topic Parameters to classicladder possible?
i ended up using the angle float for displaying how much the angle is in degrees.
- Thank you received: 2181
15 Feb 2020 14:16 #157482
Replied by cmorley on topic Parameters to classicladder possible?
classicladder actual truncates the float (chops it off at the decimal)
Rounding would probably been better.
A work around is to multiply the float by 100 or 1000 before sending to classicladder - I've used this for a modbus vfd once...
15 Feb 2020 14:19 #157484
I like your indicator - I might need to add this to qtvcp's offset dialog - would you mind if I used your image?
- 3D-Master
15 Feb 2020 15:52 #157490
by 3D-Master
feel free to use it
- 3D-Master
15 Feb 2020 15:54 - 15 Feb 2020 16:20 #157491
by 3D-Master
but keep in mind that this indicator is a screenshot of the original indicator from Heidenhain (i downloaded the free to download CNC controller software "Programmierplatz" and made screenshots of almost every icon or softbutton).
actually i dont know what they would do if they would see this :/
but a derivation should be no problem
Last edit: 15 Feb 2020 16:20 by 3D-Master.
Time to create page: 0.819 seconds
