Needing help, edit HAL for M19
15 Feb 2020 06:36 #157428 by SOLD
Needing help, edit HAL for M19 was created by SOLD
I'm starting Linuxcnc with Brother TC217 without any knowledge of Linux. I use Mesa 7i92 + 7i77 with Linuxcnc2.8. Right now my TC217 works well.
I got information from here.
forum.linuxcnc.org/30-cnc-machines/32276...225-tc-229-adventure
github.com/laserK3000/tc215Retrofit
The HAL example I received might be the Machineki version. Now, I'm doing the ATC steps. There is a problem. M19 doesn't work.
In my HAL file, there are still some parts that can't be enabled:
#newinst orn spindle-enable-or pincount=3
#loadrt debounce names=debounce-spindle count=1
And other commands may have issues Or not, I'm not sure At this time it can work except for the M19 R360 Q10 P1. It does not respond in due time.
Please help me.
Thank.
File Name: 217ATC_2020-02-15.hal
File Size:19 KB
File Name: 217ATC_2020-02-15.ini
File Size:4 KB
The following user(s) said Thank You: akb1212
16 Feb 2020 02:47 #157508 by bbsr_5a
Replied by bbsr_5a on topic Needing help, edit HAL for M19
Hi
R360 isnot well
use R359.9 or 0 for pos ATC
it is better to displace the sensor to a non Zero/360 Pos to get a movement
you are saying the INI workes
There is no Comment # this shoudt issue a error
[PYTHON]
PATH_PREPEND=./python
PATH_APPEND=/home/cnc/linuxcnc/nc_files/remap_lib/python-stdglue
import the following Python module
TOPLEVEL=python/toplevel.py
XY is homing at the same Time not the best even on Servos 7i77
can you post xour toolchange remap ngc hat commands are issued to the orient
The following user(s) said Thank You: SOLD
16 Feb 2020 03:52 - 16 Feb 2020 03:56 #157512 by SOLD
Replied by SOLD on topic Needing help, edit HAL for M19
Thank you for guiding
R360 isnot well
-Ok, got it. But I called 90. 180. Or any number, it didn't respond.
[PYTHON]
You mean that I should close # in these commands. Is that correct?
-Ok, got it. I will do as you say
File Name: toolchange.ngc
File Size:4 KB
File Name: toplevel.py
File Size:0 KB
File Name: remap.py
File Size:0 KB
Last edit: 16 Feb 2020 03:56 by SOLD. Reason: attachment
Time to create page: 0.151 seconds
