- Configuring LinuxCNC
- HAL
- Dig IOs visible on HAL (shows Set and Reset by M64,M65) but no physical change
- Schneckerich_63
29 Feb 2020 04:21 - 29 Feb 2020 12:22 #158800
by Schneckerich_63
Dig IOs visible on HAL (shows Set and Reset by M64,M65) but no physical change was created by Schneckerich_63
Hallo
I am working with 7i76e and 7i85s. For Testpurposes i only use one axis in closed loop mode. It runs very well.
Closed Loop is very satisviing.
The Hal based definition of IOs works internally very fine. In HAL i obeye the outputs adressed by their GPIO Pin.
As used in cnc program by M64 and M65 they switch on and off as expected.
But here starts the Problem. Measuring with Digital Multimeter in DC Volt range the Outputs Show absolutely no Change.
For Power supply i am working with TB1 Field power Pin 8 GND , Pin 5 24V and TB3 Power Pin 23 GND, Pin 22 24V
Defining of Limit switches in Hal is in my opinoun correct. When i start my cnc prog i receive at once an errormessage caused by
the limit switch which does not gets any voltage Information.
My last try was to Change the Mode of 7i76e from 0 onto 2.
I hope one of you can give me an additionately Information to solve this Problem .
In the attachement you will find hal and ini files, may be there are some informations still missing. I worked
with a project given by talla83 (Youtube).
I switched from mach3 to linuxcnc and be shure it was a good decision.
Thanks to all
Schneckerich_63
Thanks to all
Schneckerich_63
Last edit: 29 Feb 2020 12:22 by Schneckerich_63.
- BeagleBrainz
- Visitor
29 Feb 2020 04:46 #158802
by BeagleBrainz
Replied by BeagleBrainz on topic Dig IOs visible on HAL (shows Set and Reset by M64,M65) but no physical change
You forgotten to attach the hal & ini files.
You do have the read & write functions added to the thread ?
I forgot to do this once when using halrun when doing some testing.
- Thank you received: 7504
29 Feb 2020 05:19 #158803
Replied by tommylight on topic Dig IOs visible on HAL (shows Set and Reset by M64,M65) but no physical change
The digital IO's are not connected to physical outputs in hal.
Something like
net dout-00 <= motion.digital-out-00
net dout-01 <= motion.digital-out-01
net dout-02 <= motion.digital-out-02
net dout-03 <= motion.digital-out-03
net dout-00 => parport.0.pin-08-out
net dout-01 => parport.0.pin-09-out
net dout-02 => parport.0.pin-14-out
net dout-03 => parport.0.pin-16-out
Change parport entries to mesa if needed
Something like
The following user(s) said Thank You: BeagleBrainz
- Schneckerich_63
29 Feb 2020 12:25 #158832
by Schneckerich_63
Replied by Schneckerich_63 on topic Dig IOs visible on HAL (shows Set and Reset by M64,M65) but no physical change
Thank you BeagleBrtainz
now i added hal and ini may be you can see something wrong.
as i understood the man read and write are correct.
Schneckerich_63
Schneckerich_63
- Schneckerich_63
29 Feb 2020 12:31 #158833
by Schneckerich_63
Thank you tommylight,
i forgot to addon the hal and ini file. This was done now.
I suppose your proposel is already part of hal.
May be a glance on my files will give you an additionately idea.
Schneckerich_63.
Schneckerich_63.
- Thank you received: 5336
29 Feb 2020 15:12 #158842
Replied by PCW on topic Dig IOs visible on HAL (shows Set and Reset by M64,M65) but no physical change
You may be better off starting with a pncconf created hal/ini file set
The field I/O on a 7I76E is not GPIO but rather:
halcmd show pin hm2_7i76e.0.7i76.0.0.*
Component Pins:
Owner Type Dir Value Name
23 float OUT 0 hm2_7i76e.0.7i76.0.0.analogin0
23 float OUT 0 hm2_7i76e.0.7i76.0.0.analogin1
23 float OUT 0 hm2_7i76e.0.7i76.0.0.analogin2
23 float OUT 0 hm2_7i76e.0.7i76.0.0.analogin3
23 s32 OUT 0 hm2_7i76e.0.7i76.0.0.enc0.count
23 bit I/O FALSE hm2_7i76e.0.7i76.0.0.enc0.index-enable
23 float OUT 0 hm2_7i76e.0.7i76.0.0.enc0.position
23 s32 OUT 0 hm2_7i76e.0.7i76.0.0.enc0.rawcounts
23 bit I/O FALSE hm2_7i76e.0.7i76.0.0.enc0.reset
23 s32 OUT 0 hm2_7i76e.0.7i76.0.0.enc1.count
23 bit I/O FALSE hm2_7i76e.0.7i76.0.0.enc1.index-enable
23 float OUT 0 hm2_7i76e.0.7i76.0.0.enc1.position
23 s32 OUT 0 hm2_7i76e.0.7i76.0.0.enc1.rawcounts
23 bit I/O FALSE hm2_7i76e.0.7i76.0.0.enc1.reset
23 float OUT 14.3217 hm2_7i76e.0.7i76.0.0.fieldvoltage
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-00
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-00-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-01
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-01-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-02
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-02-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-03
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-03-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-04
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-04-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-05
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-05-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-06
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-06-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-07
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-07-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-08
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-08-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-09
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-09-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-10
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-10-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-11
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-11-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-12
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-12-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-13
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-13-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-14
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-14-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-15
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-15-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-16
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-16-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-17
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-17-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-18
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-18-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-19
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-19-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-20
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-20-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-21
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-21-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-22
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-22-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-23
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-23-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-24
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-24-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-25
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-25-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-26
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-26-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-27
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-27-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-28
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-28-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-29
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-29-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-30
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-30-not
23 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-31
23 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-31-not
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-00
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-01
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-02
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-03
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-04
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-05
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-06
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-07
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-08
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-09
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-10
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-11
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-12
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-13
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-14
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-15
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.spindir
23 bit IN FALSE hm2_7i76e.0.7i76.0.0.spinena
23 float IN 0 hm2_7i76e.0.7i76.0.0.spinout
Component Pins:
- Schneckerich_63
02 Mar 2020 09:31 #158983
by Schneckerich_63
Hallo PCW,
thank your for the fast Help.
At the Moment my Problem is solved. your assumption something
is wrong in HAL was Right.
Bye
Schneckerich_63
Bye
Schneckerich_63
02 Mar 2020 14:23 #159022
What was wrong ?Hallo PCW,
Bye
Schneckerich_63
- Schneckerich_63
03 Mar 2020 05:55 - 03 Mar 2020 06:02 #159071
by Schneckerich_63
Hallo Tommylight
I added the new working Hal file. Comparing to the old Hal file in my Question you will see at once my faults.
Not all io were tested, but works one they will work all i suppose.
Thanks to all.
Schneckerich_63
Thanks to all.
Schneckerich_63
Last edit: 03 Mar 2020 06:02 by Schneckerich_63.
- HAL
Time to create page: 0.108 seconds
