Spindle-at-speed with direction
19 Mar 2020 01:20 #160713 by kimachren
Spindle-at-speed with direction was created by kimachren
I'm trying to figure out how do do a spindle-at-speed check with direction awareness.
The problem is that when doing a M4 S2000 (-2000rpm) from a previous M3 S3000 (+3000rpm), the "near" function triggers the spindle-at-speed already at +2000rpm. I have tried to use a comp with encoder velocity against 0 (zero) to get the direction of the actual rotation and "and"-ing it with "spindle-reverse"-signal to check if it is rotating in correct direction. The problem with this is that and2 only gives TRUE when both inputs are TRUE and hence no luck when spindle-reverse is FALSE.
Any suggestions?
19 Mar 2020 02:21 #160716 by cmorley
Replied by cmorley on topic Spindle-at-speed with direction
how do you have it connected now - can you post your HAL files?
19 Mar 2020 02:56 - 19 Mar 2020 02:57 #160717 by alkabal
Replied by alkabal on topic Spindle-at-speed with direction
Hi
You can use the not component for reversing bit status
Or (better) use lut5 you can connect 5 signal and mix 0/1 status.
Br
Last edit: 19 Mar 2020 02:57 by alkabal.
The following user(s) said Thank You: kimachren
19 Mar 2020 03:07 #160718 by kimachren
Replied by kimachren on topic Spindle-at-speed with direction
I can't post HAL files now because I'm at work, and the machine is at home.
But this is the principle (same as everybody elses for sure):
net .... ... pid.s.command -> near.0.in0
net .... .. pid.s.feedback -> near.0.in1
net spindle-at-speed ... .. near.0.out
I tried something like this:
setp comp.0.in0 0 (zero)
net .... hm2..encoder...velocity -> comp.0.in1 (pins may have been the opposite)
net .... .... and2.0.in0 comp.0.out
net spindle-reverse .... and2.0.in1
net .... and2.1.in0 and2.0.out
net ...and2.1.in1 near.0.out
net spindle-at-speed and2.1.out
Does not work when spindle-reverse is FALSE even though the direction is correct, because and2 only gives TRUE when inputs are TRUE.
19 Mar 2020 03:53 #160720 by kimachren
thanks alkabal, lut5 looks like what I need.
19 Mar 2020 07:06 #160736 by bbsr_5a
Replied by bbsr_5a on topic Spindle-at-speed with direction
you got also the direction signals from Hal that you can mix in your logic
20 Mar 2020 03:55 #160843 by kimachren
I'm unsure what signals you mean, but I got it working the way I described above. Just changing the two ands to lut5 with 100 and 111 as bit masks.
in0 is actual direction from encoder
in1 is wanted direction from program (reverse signal)
in2 is output from near.
22 Mar 2020 19:54 #161162 by andypugh
Replied by andypugh on topic Spindle-at-speed with direction
I think that the problem might be that you are looking at feedback and command that are possibly already absolute?
Try feeding the near component from the signed spindle.0.speed pin (or motion.spindle-speed-out) and comparing that to the signed version of the encoder velocity.
Time to create page: 0.276 seconds
