Override for Angular Jog Speed?
  • Aciera
  • Aciera's Avatar Topic Author
  • Administrator
  • Administrator
21 Mar 2020 16:54 #160992 by Aciera
Override for Angular Jog Speed? was created by Aciera
Is there a HAL pin to override the angular jog speed in LinuxCNC 2.8?
thanks
21 Mar 2020 17:07 #161000 by tommylight
Replied by tommylight on topic Override for Angular Jog Speed?
Why double posting ?
  • Aciera
  • Administrator
  • Administrator
21 Mar 2020 18:01 #161013 by Aciera
Replied by Aciera on topic Override for Angular Jog Speed?
Because I dont see it as a double post as gmoccapy uses different Hal pins than axis does.
21 Mar 2020 19:12 #161019 by tommylight
I thought so, just had to be sure.
Thank you.
I did try to find the pin in axis, but there is no search function. Maybe doing a pin dump from terminal and then using text editor to search could yield results ?
21 Mar 2020 19:13 #161020 by cmorley
Replied by cmorley on topic Override for Angular Jog Speed?
linuxcnc has no internally tracked jog rate - each GUI has it's own.
If the GUI gives no access to it's internals then you are out of luck.
assuming you want to be able to use the GUI's controls.
It's probably possible with AXIS, but you'll need to figure out how - there is not much for documentation.
Gmoccapy -I don't think it gives access at all.
Asking in one thread would have been fine (ie I'm not going to answer the other thread)
Chris
21 Mar 2020 19:22 #161021 by tommylight
In terminal, while Linuxcnc is running:
halcmd -kf | tee pin.txt
then
show pin
It creates the pin.txt file in your home directory with all the pins available, so you can search with a text editor.
  • Aciera
  • Administrator
  • Administrator
22 Mar 2020 07:04 #161074 by Aciera
thanks, I deleted the other thread.
Time to create page: 0.090 seconds
