[solved] Unable to jog axis through halui pins
  • Aciera
  • Aciera's Avatar Topic Author
  • Administrator
  • Administrator
23 Mar 2020 02:44 - 23 Mar 2020 21:48 #161196 by Aciera
On my machine I use panel buttons for jogging.
Now I switched my system to LinucCNC 2.8 from 2.7 and have trouble getting the jogging buttons to work.
Jogging works with the keyboard and the mouse buttons on the axis ui.
(My panel buttons also work in gmoccapy but that uses its own halpins for jogging)
It used to work like this:
net x-plus-panel            => halui.axis.x.plus
net x-minus-panel           => halui.axis.x.minus
net y-plus-panel            => halui.axis.y.plus
net y-minus-panel           => halui.axis.y.minus
net z-plus-panel            => halui.axis.z.plus
net z-minus-panel           => halui.axis.z.minus
net a-plus-panel            => halui.axis.a.plus
net a-minus-panel           => halui.axis.a.minus
Now I can see halui.axis.x.plus becomes active when I press the panel button and I can see that halui.axis.jog-speed is not zero but the axis does not move.
I would really appreciate it if somebody could give me a hint.
File Name: Vertikal_X...rmal.hal
File Size:26 KB
File Name: Vertikal_X...rmal.ini
File Size:6 KB
Last edit: 23 Mar 2020 21:48 by Aciera.
23 Mar 2020 04:50 #161201 by cmorley
Replied by cmorley on topic Unable to jog axis throug halui pins
Is this before you have homed? before homing there are only joints.
\Might need to add the joint pins
halui.joint.0.plus
Time to create page: 0.987 seconds
