Retrofitting an existing Ethercat machine
- Niko
- Thank you received: 5
26 Apr 2020 06:16 #165653
by Niko
Retrofitting an existing Ethercat machine was created by Niko
Hi all,
as it turns out I'll have the chance to retrofit a brand new 5 axis machine that already uses Ethercat hardware . Thing is it's fitted with power automation components, so that's another thing to have in mind .
I have absolutely no experience with Ethercat on LCNC, and i"d like to get a head start with some reading and researching .
Is it possible to use non Beckhoff equipment ?
How do I go about getting everything in hal ?
Any input is welcome .
Thank you in advance .
Cheers
Nikolai
Cheers
Nikolai
- bbsr_5a
- Thank you received: 106
26 Apr 2020 07:52 #165657
by bbsr_5a
Replied by bbsr_5a on topic Retrofitting an existing Ethercat machine
if you are willing to invest some Money you coudt better change to a Mesa setup
that gives you the full comunity background
or as you are within some base cnc stuff fast respond
with only a view cable changes
if the driver board is one of this list you are quick on the system as it is supported
EtherCatDriver
wiki.linuxcnc.org/cgi-bin/wiki.pl?back=EtherCatDriver
100+ pages of info here
EtherCatDriver
- Niko
26 Apr 2020 08:41 - 26 Apr 2020 08:42 #165663
by Niko
Replied by Niko on topic Retrofitting an existing Ethercat machine
I have thought about switching over to Mesa hardware but that won't be too logical . The drives are with absolute encoders and Ethercat communication and it would be a shame to switch back to analog .
Last edit: 26 Apr 2020 08:42 by Niko.
- Thank you received: 7504
26 Apr 2020 08:45 #165665
Replied by tommylight on topic Retrofitting an existing Ethercat machine
There are several users here that use ethercat, so might want to wait for them to reply.
In the mean time, you should provide much more information about the drives, control boards, etc.
- chimeno
- Thank you received: 125
27 Apr 2020 15:14 - 27 Apr 2020 15:14 #165868
by chimeno
Replied by chimeno on topic Retrofitting an existing Ethercat machine
Hi @Niko,If possible without problems, the best way to start is with the generic driver included in linuxcnc-ethercat, there are several examples here in the forum.
It seems like a great project, very interesting, if you don't have a lot of knowledge and work is in a hurry, the best thing would be to go to MESA, if you have time and you want to do it all!Hi all,
Is it possible to use non Beckhoff equipment ?You have to do a little research on linuxcnc-ethercat, it is not very difficult if you have some knowledge, it is just time and bad head.How do I go about getting everything in hal ?
Last edit: 27 Apr 2020 15:14 by chimeno. Reason: Edit
Time to create page: 0.164 seconds
