HAL Pin not setting
- Thank you received: 4155
28 Apr 2020 00:33 #165903
HAL Pin not setting was created by rodw
I don't understand.
I am trying to use a plasmac Pin in a custom component (plasmac.thc_active)
At first I thought I it was becasue it was defined in plasmac_monitor.hal so it needed to be post_gui
So I tried that and failed
so I edited plasmac_monitor.hal like this
I can monitor these pins in Halscope.
The signal net plasmac:thc_active is working as expected but my pin thcad10.thc-is-active which should urn on and off in unison is never set. Other pins in my component are working as I expected so I don't understand why the signal is npt passed to the component.
Any Ideas? This is very perplexing and I've wasted hours on this.
net plasmac:thc-active <= plasmac.thc-active
net plasmac:thc_active => plasmac_monitor.led-thc-active
net plasmac:thc_active => thcad10.thc-is-activeI can monitor these pins in Halscope.
- bbsr_5a
- Thank you received: 106
28 Apr 2020 01:56 #165910
by bbsr_5a
Replied by bbsr_5a on topic HAL Pin not setting
if you use a HAL NET it will work
net myplasmac_thc-active <= plasmac.thc-active
net myplasmac_thc-active => plasmac_monitor.led-thc-active
net myplasmac_thc-active => thcad10.thc-is-active
isent internal interpreter the SAME pin not to be set
28 Apr 2020 02:01 #165912
I have done that. Just that we have used a : in the signal name. Look closely
I doubt that is the issue. plasmac_monitor.led-thc-active lights up
But I'm not at the machine now.
Replied by rodw on topic HAL Pin not setting
plasmac:thc-activeI doubt that is the issue. plasmac_monitor.led-thc-active lights up
- bbsr_5a
28 Apr 2020 02:19 #165916
by bbsr_5a
im not that programmer
but isent the ":" to interpreter a C-Component command bridge and therfor running into a non execute as the interpreter cand interpret it
Time to create page: 0.143 seconds
