Suggestions and help needed
- shilo14
17 May 2020 03:41 #168034
by shilo14
Suggestions and help needed was created by shilo14
Help
Neje 7w laser module, Laser link
Chinese 5 axis breakout board. (works great as a hobby cnc controller)
Control board image
has anyone ever managed to make a happy marriage from this couple.
I'm getting old and the grey matter aint what it used to be.
Control board image
- bbsr_5a
- Thank you received: 106
18 May 2020 06:17 #168137
by bbsr_5a
Replied by bbsr_5a on topic Suggestions and help needed
hi will work great
you can even control the laser power by spindle speed
if you setup a new router use a 3D printer setup as the light got unlimitespeed ypou can go 500+mm/sec
you wont reatch tis speed on nallscrew go for timingbelt and as of low weight to be moved the 6USD 2meter 3D printer Gt2 sets are to be considerd
if you do not need to be on CNC controller at all
there is a inkscape LASER setup that uses a rrduino shieldl L293D 4USD that controlls 2 Nema17
Via USB full magic controll
The following user(s) said Thank You: shilo14
