HAL setup for MPG Pendant
6 years 2 weeks ago #186249 by Arland
Hi All,
I am having a hell of a time configuring my MPG pendant. The only thing that is working is the Estop.
Here is how I wired it up -
It is this pendant www.amazon.com/gp/product/B07CZ7F3Y3/ref...06_s00?ie=UTF8&psc=1
Here is my current config -
# Generated by PNCconf at Thu Oct 15 21:55:59 2020 # Using LinuxCNC version: 2.8 # If you make changes to this file, they will be # overwritten when you run PNCconf again loadrt [KINS]KINEMATICS loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS loadrt hostmot2 loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx" setp hm2_7i76e.0.watchdog.timeout_ns 5000000 loadrt pid names=pid.x,pid.y,pid.z,pid.s addf hm2_7i76e.0.read servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf pid.x.do-pid-calcs servo-thread addf pid.y.do-pid-calcs servo-thread addf pid.z.do-pid-calcs servo-thread addf pid.s.do-pid-calcs servo-thread addf hm2_7i76e.0.write servo-thread setp hm2_7i76e.0.dpll.01.timer-us -50 setp hm2_7i76e.0.stepgen.timer-number 1 # external output signals # external input signals # --- JOINT-SELECT-A --- net joint-select-a <= hm2_7i76e.0.7i76.0.0.input-07 # --- JOINT-SELECT-B --- net joint-select-b <= hm2_7i76e.0.7i76.0.0.input-08 # --- JOINT-SELECT-C --- net joint-select-c <= hm2_7i76e.0.7i76.0.0.input-09 # --- JOG-INCR-C --- net jog-incr-c <= hm2_7i76e.0.7i76.0.0.input-10 # --- JOG-INCR-B --- net jog-incr-b <= hm2_7i76e.0.7i76.0.0.input-11 # --- JOG-INCR-A --- net jog-incr-a <= hm2_7i76e.0.7i76.0.0.input-12 # --- ESTOP-EXT --- net estop-ext <= hm2_7i76e.0.7i76.0.0.input-13 # --- PROBE-IN --- net probe-in <= hm2_7i76e.0.7i76.0.0.input-20 #******************* # AXIS X JOINT 0 #******************* setp pid.x.Pgain [JOINT_0]P setp pid.x.Igain [JOINT_0]I setp pid.x.Dgain [JOINT_0]D setp pid.x.bias [JOINT_0]BIAS setp pid.x.FF0 [JOINT_0]FF0 setp pid.x.FF1 [JOINT_0]FF1 setp pid.x.FF2 [JOINT_0]FF2 setp pid.x.deadband [JOINT_0]DEADBAND setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT setp pid.x.error-previous-target true # This setting is to limit bogus stepgen # velocity corrections caused by position # feedback sample time jitter. setp pid.x.maxerror 0.000500 net x-index-enable <=> pid.x.index-enable net x-enable => pid.x.enable net x-pos-cmd => pid.x.command net x-pos-fb => pid.x.feedback net x-output <= pid.x.output # Step Gen signals/setup setp hm2_7i76e.0.stepgen.00.dirsetup [JOINT_0]DIRSETUP setp hm2_7i76e.0.stepgen.00.dirhold [JOINT_0]DIRHOLD setp hm2_7i76e.0.stepgen.00.steplen [JOINT_0]STEPLEN setp hm2_7i76e.0.stepgen.00.stepspace [JOINT_0]STEPSPACE setp hm2_7i76e.0.stepgen.00.position-scale [JOINT_0]STEP_SCALE setp hm2_7i76e.0.stepgen.00.step_type 0 setp hm2_7i76e.0.stepgen.00.control-type 1 setp hm2_7i76e.0.stepgen.00.maxaccel [JOINT_0]STEPGEN_MAXACCEL setp hm2_7i76e.0.stepgen.00.maxvel [JOINT_0]STEPGEN_MAXVEL # ---closedloop stepper signals--- net x-pos-cmd <= joint.0.motor-pos-cmd net x-vel-cmd <= joint.0.vel-cmd net x-output <= hm2_7i76e.0.stepgen.00.velocity-cmd net x-pos-fb <= hm2_7i76e.0.stepgen.00.position-fb net x-pos-fb => joint.0.motor-pos-fb net x-enable <= joint.0.amp-enable-out net x-enable => hm2_7i76e.0.stepgen.00.enable # ---setup home / limit switch signals--- net x-home-sw => joint.0.home-sw-in net x-neg-limit => joint.0.neg-lim-sw-in net x-pos-limit => joint.0.pos-lim-sw-in #******************* # AXIS Y JOINT 1 #******************* setp pid.y.Pgain [JOINT_1]P setp pid.y.Igain [JOINT_1]I setp pid.y.Dgain [JOINT_1]D setp pid.y.bias [JOINT_1]BIAS setp pid.y.FF0 [JOINT_1]FF0 setp pid.y.FF1 [JOINT_1]FF1 setp pid.y.FF2 [JOINT_1]FF2 setp pid.y.deadband [JOINT_1]DEADBAND setp pid.y.maxoutput [JOINT_1]MAX_OUTPUT setp pid.y.error-previous-target true # This setting is to limit bogus stepgen # velocity corrections caused by position # feedback sample time jitter. setp pid.y.maxerror 0.000500 net y-index-enable <=> pid.y.index-enable net y-enable => pid.y.enable net y-pos-cmd => pid.y.command net y-pos-fb => pid.y.feedback net y-output <= pid.y.output # Step Gen signals/setup setp hm2_7i76e.0.stepgen.01.dirsetup [JOINT_1]DIRSETUP setp hm2_7i76e.0.stepgen.01.dirhold [JOINT_1]DIRHOLD setp hm2_7i76e.0.stepgen.01.steplen [JOINT_1]STEPLEN setp hm2_7i76e.0.stepgen.01.stepspace [JOINT_1]STEPSPACE setp hm2_7i76e.0.stepgen.01.position-scale [JOINT_1]STEP_SCALE setp hm2_7i76e.0.stepgen.01.step_type 0 setp hm2_7i76e.0.stepgen.01.control-type 1 setp hm2_7i76e.0.stepgen.01.maxaccel [JOINT_1]STEPGEN_MAXACCEL setp hm2_7i76e.0.stepgen.01.maxvel [JOINT_1]STEPGEN_MAXVEL # ---closedloop stepper signals--- net y-pos-cmd <= joint.1.motor-pos-cmd net y-vel-cmd <= joint.1.vel-cmd net y-output <= hm2_7i76e.0.stepgen.01.velocity-cmd net y-pos-fb <= hm2_7i76e.0.stepgen.01.position-fb net y-pos-fb => joint.1.motor-pos-fb net y-enable <= joint.1.amp-enable-out net y-enable => hm2_7i76e.0.stepgen.01.enable # ---setup home / limit switch signals--- net y-home-sw => joint.1.home-sw-in net y-neg-limit => joint.1.neg-lim-sw-in net y-pos-limit => joint.1.pos-lim-sw-in #******************* # AXIS Z JOINT 2 #******************* setp pid.z.Pgain [JOINT_2]P setp pid.z.Igain [JOINT_2]I setp pid.z.Dgain [JOINT_2]D setp pid.z.bias [JOINT_2]BIAS setp pid.z.FF0 [JOINT_2]FF0 setp pid.z.FF1 [JOINT_2]FF1 setp pid.z.FF2 [JOINT_2]FF2 setp pid.z.deadband [JOINT_2]DEADBAND setp pid.z.maxoutput [JOINT_2]MAX_OUTPUT setp pid.z.error-previous-target true # This setting is to limit bogus stepgen # velocity corrections caused by position # feedback sample time jitter. setp pid.z.maxerror 0.000500 net z-index-enable <=> pid.z.index-enable net z-enable => pid.z.enable net z-pos-cmd => pid.z.command net z-pos-fb => pid.z.feedback net z-output <= pid.z.output # Step Gen signals/setup setp hm2_7i76e.0.stepgen.02.dirsetup [JOINT_2]DIRSETUP setp hm2_7i76e.0.stepgen.02.dirhold [JOINT_2]DIRHOLD setp hm2_7i76e.0.stepgen.02.steplen [JOINT_2]STEPLEN setp hm2_7i76e.0.stepgen.02.stepspace [JOINT_2]STEPSPACE setp hm2_7i76e.0.stepgen.02.position-scale [JOINT_2]STEP_SCALE setp hm2_7i76e.0.stepgen.02.step_type 0 setp hm2_7i76e.0.stepgen.02.control-type 1 setp hm2_7i76e.0.stepgen.02.maxaccel [JOINT_2]STEPGEN_MAXACCEL setp hm2_7i76e.0.stepgen.02.maxvel [JOINT_2]STEPGEN_MAXVEL # ---closedloop stepper signals--- net z-pos-cmd <= joint.2.motor-pos-cmd net z-vel-cmd <= joint.2.vel-cmd net z-output <= hm2_7i76e.0.stepgen.02.velocity-cmd net z-pos-fb <= hm2_7i76e.0.stepgen.02.position-fb net z-pos-fb => joint.2.motor-pos-fb net z-enable <= joint.2.amp-enable-out net z-enable => hm2_7i76e.0.stepgen.02.enable # ---setup home / limit switch signals--- net z-home-sw => joint.2.home-sw-in net z-neg-limit => joint.2.neg-lim-sw-in net z-pos-limit => joint.2.pos-lim-sw-in #****************************** # connect miscellaneous signals #****************************** # ---HALUI signals--- net axis-select-x halui.axis.x.select net jog-x-pos halui.axis.x.plus net jog-x-neg halui.axis.x.minus net jog-x-analog halui.axis.x.analog net x-is-homed halui.joint.0.is-homed net axis-select-y halui.axis.y.select net jog-y-pos halui.axis.y.plus net jog-y-neg halui.axis.y.minus net jog-y-analog halui.axis.y.analog net y-is-homed halui.joint.1.is-homed net axis-select-z halui.axis.z.select net jog-z-pos halui.axis.z.plus net jog-z-neg halui.axis.z.minus net jog-z-analog halui.axis.z.analog net z-is-homed halui.joint.2.is-homed net jog-selected-pos halui.axis.selected.plus net jog-selected-neg halui.axis.selected.minus net spindle-manual-cw halui.spindle.0.forward net spindle-manual-ccw halui.spindle.0.reverse net spindle-manual-stop halui.spindle.0.stop net machine-is-on halui.machine.is-on net jog-speed halui.axis.jog-speed net MDI-mode halui.mode.is-mdi # ---coolant signals--- net coolant-mist <= iocontrol.0.coolant-mist net coolant-flood <= iocontrol.0.coolant-flood # ---probe signal--- net probe-in => motion.probe-input # ---motion control signals--- net in-position <= motion.in-position net machine-is-enabled <= motion.motion-enabled # ---digital in / out signals--- # ---estop signals--- net estop-out <= iocontrol.0.user-enable-out net estop-ext => iocontrol.0.emc-enable-in # ---manual tool change signals--- loadusr -W hal_manualtoolchange net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
I am a complete noob at this stuff so any advice is welcome! I am sure it is super obvious.
6 years 2 weeks ago #186424 by Arland
Replied by Arland on topic HAL setup for MPG Pendant
Update to my code here - made some big changes - Estop now works.
# Generated by PNCconf at Thu Oct 15 21:55:59 2020 # Using LinuxCNC version: 2.8 # If you make changes to this file, they will be # overwritten when you run PNCconf again loadrt [KINS]KINEMATICS loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS loadrt hostmot2 loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=2xxxx" setp hm2_7i76e.0.watchdog.timeout_ns 5000000 loadrt pid names=pid.x,pid.y,pid.z,pid.s loadrt estop_latch loadrt or2 loadrt encoder num_chan=1 loadrt mux4 count=1 addf encoder.capture-position servo-thread addf mux4.0 servo-thread addf hm2_7i76e.0.read servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf pid.x.do-pid-calcs servo-thread addf pid.y.do-pid-calcs servo-thread addf pid.z.do-pid-calcs servo-thread addf pid.s.do-pid-calcs servo-thread addf hm2_7i76e.0.write servo-thread setp hm2_7i76e.0.dpll.01.timer-us -50 setp hm2_7i76e.0.stepgen.timer-number 1 # external output signals # external input signals # --- ESTOP-EXT --- net estop-ext <= hm2_7i76e.0.7i76.0.0.input-13 # --- PROBE-IN --- net probe-in <= hm2_7i76e.0.7i76.0.0.input-20 #******************* # AXIS X JOINT 0 #******************* setp pid.x.Pgain [JOINT_0]P setp pid.x.Igain [JOINT_0]I setp pid.x.Dgain [JOINT_0]D setp pid.x.bias [JOINT_0]BIAS setp pid.x.FF0 [JOINT_0]FF0 setp pid.x.FF1 [JOINT_0]FF1 setp pid.x.FF2 [JOINT_0]FF2 setp pid.x.deadband [JOINT_0]DEADBAND setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT setp pid.x.error-previous-target true # This setting is to limit bogus stepgen # velocity corrections caused by position # feedback sample time jitter. setp pid.x.maxerror 0.000500 net x-index-enable <=> pid.x.index-enable net x-enable => pid.x.enable net x-pos-cmd => pid.x.command net x-pos-fb => pid.x.feedback net x-output <= pid.x.output # Step Gen signals/setup setp hm2_7i76e.0.stepgen.00.dirsetup [JOINT_0]DIRSETUP setp hm2_7i76e.0.stepgen.00.dirhold [JOINT_0]DIRHOLD setp hm2_7i76e.0.stepgen.00.steplen [JOINT_0]STEPLEN setp hm2_7i76e.0.stepgen.00.stepspace [JOINT_0]STEPSPACE setp hm2_7i76e.0.stepgen.00.position-scale [JOINT_0]STEP_SCALE setp hm2_7i76e.0.stepgen.00.step_type 0 setp hm2_7i76e.0.stepgen.00.control-type 1 setp hm2_7i76e.0.stepgen.00.maxaccel [JOINT_0]STEPGEN_MAXACCEL setp hm2_7i76e.0.stepgen.00.maxvel [JOINT_0]STEPGEN_MAXVEL # ---closedloop stepper signals--- net x-pos-cmd <= joint.0.motor-pos-cmd net x-vel-cmd <= joint.0.vel-cmd net x-output <= hm2_7i76e.0.stepgen.00.velocity-cmd net x-pos-fb <= hm2_7i76e.0.stepgen.00.position-fb net x-pos-fb => joint.0.motor-pos-fb net x-enable <= joint.0.amp-enable-out net x-enable => hm2_7i76e.0.stepgen.00.enable # ---setup home / limit switch signals--- net x-home-sw => joint.0.home-sw-in net x-neg-limit => joint.0.neg-lim-sw-in net x-pos-limit => joint.0.pos-lim-sw-in #******************* # AXIS Y JOINT 1 #******************* setp pid.y.Pgain [JOINT_1]P setp pid.y.Igain [JOINT_1]I setp pid.y.Dgain [JOINT_1]D setp pid.y.bias [JOINT_1]BIAS setp pid.y.FF0 [JOINT_1]FF0 setp pid.y.FF1 [JOINT_1]FF1 setp pid.y.FF2 [JOINT_1]FF2 setp pid.y.deadband [JOINT_1]DEADBAND setp pid.y.maxoutput [JOINT_1]MAX_OUTPUT setp pid.y.error-previous-target true # This setting is to limit bogus stepgen # velocity corrections caused by position # feedback sample time jitter. setp pid.y.maxerror 0.000500 net y-index-enable <=> pid.y.index-enable net y-enable => pid.y.enable net y-pos-cmd => pid.y.command net y-pos-fb => pid.y.feedback net y-output <= pid.y.output # Step Gen signals/setup setp hm2_7i76e.0.stepgen.01.dirsetup [JOINT_1]DIRSETUP setp hm2_7i76e.0.stepgen.01.dirhold [JOINT_1]DIRHOLD setp hm2_7i76e.0.stepgen.01.steplen [JOINT_1]STEPLEN setp hm2_7i76e.0.stepgen.01.stepspace [JOINT_1]STEPSPACE setp hm2_7i76e.0.stepgen.01.position-scale [JOINT_1]STEP_SCALE setp hm2_7i76e.0.stepgen.01.step_type 0 setp hm2_7i76e.0.stepgen.01.control-type 1 setp hm2_7i76e.0.stepgen.01.maxaccel [JOINT_1]STEPGEN_MAXACCEL setp hm2_7i76e.0.stepgen.01.maxvel [JOINT_1]STEPGEN_MAXVEL # ---closedloop stepper signals--- net y-pos-cmd <= joint.1.motor-pos-cmd net y-vel-cmd <= joint.1.vel-cmd net y-output <= hm2_7i76e.0.stepgen.01.velocity-cmd net y-pos-fb <= hm2_7i76e.0.stepgen.01.position-fb net y-pos-fb => joint.1.motor-pos-fb net y-enable <= joint.1.amp-enable-out net y-enable => hm2_7i76e.0.stepgen.01.enable # ---setup home / limit switch signals--- net y-home-sw => joint.1.home-sw-in net y-neg-limit => joint.1.neg-lim-sw-in net y-pos-limit => joint.1.pos-lim-sw-in #******************* # AXIS Z JOINT 2 #******************* setp pid.z.Pgain [JOINT_2]P setp pid.z.Igain [JOINT_2]I setp pid.z.Dgain [JOINT_2]D setp pid.z.bias [JOINT_2]BIAS setp pid.z.FF0 [JOINT_2]FF0 setp pid.z.FF1 [JOINT_2]FF1 setp pid.z.FF2 [JOINT_2]FF2 setp pid.z.deadband [JOINT_2]DEADBAND setp pid.z.maxoutput [JOINT_2]MAX_OUTPUT setp pid.z.error-previous-target true # This setting is to limit bogus stepgen # velocity corrections caused by position # feedback sample time jitter. setp pid.z.maxerror 0.000500 net z-index-enable <=> pid.z.index-enable net z-enable => pid.z.enable net z-pos-cmd => pid.z.command net z-pos-fb => pid.z.feedback net z-output <= pid.z.output # Step Gen signals/setup setp hm2_7i76e.0.stepgen.02.dirsetup [JOINT_2]DIRSETUP setp hm2_7i76e.0.stepgen.02.dirhold [JOINT_2]DIRHOLD setp hm2_7i76e.0.stepgen.02.steplen [JOINT_2]STEPLEN setp hm2_7i76e.0.stepgen.02.stepspace [JOINT_2]STEPSPACE setp hm2_7i76e.0.stepgen.02.position-scale [JOINT_2]STEP_SCALE setp hm2_7i76e.0.stepgen.02.step_type 0 setp hm2_7i76e.0.stepgen.02.control-type 1 setp hm2_7i76e.0.stepgen.02.maxaccel [JOINT_2]STEPGEN_MAXACCEL setp hm2_7i76e.0.stepgen.02.maxvel [JOINT_2]STEPGEN_MAXVEL # ---closedloop stepper signals--- net z-pos-cmd <= joint.2.motor-pos-cmd net z-vel-cmd <= joint.2.vel-cmd net z-output <= hm2_7i76e.0.stepgen.02.velocity-cmd net z-pos-fb <= hm2_7i76e.0.stepgen.02.position-fb net z-pos-fb => joint.2.motor-pos-fb net z-enable <= joint.2.amp-enable-out net z-enable => hm2_7i76e.0.stepgen.02.enable # ---setup home / limit switch signals--- net z-home-sw => joint.2.home-sw-in net z-neg-limit => joint.2.neg-lim-sw-in net z-pos-limit => joint.2.pos-lim-sw-in #****************************** # connect miscellaneous signals #****************************** # ---HALUI signals--- net axis-select-x halui.axis.x.select net jog-x-pos halui.axis.x.plus net jog-x-neg halui.axis.x.minus net jog-x-analog halui.axis.x.analog net x-is-homed halui.joint.0.is-homed net axis-select-y halui.axis.y.select net jog-y-pos halui.axis.y.plus net jog-y-neg halui.axis.y.minus net jog-y-analog halui.axis.y.analog net y-is-homed halui.joint.1.is-homed net axis-select-z halui.axis.z.select net jog-z-pos halui.axis.z.plus net jog-z-neg halui.axis.z.minus net jog-z-analog halui.axis.z.analog net z-is-homed halui.joint.2.is-homed net jog-selected-pos halui.axis.selected.plus net jog-selected-neg halui.axis.selected.minus net spindle-manual-cw halui.spindle.0.forward net spindle-manual-ccw halui.spindle.0.reverse net spindle-manual-stop halui.spindle.0.stop net machine-is-on halui.machine.is-on net jog-speed halui.axis.jog-speed net MDI-mode halui.mode.is-mdi # ---coolant signals--- net coolant-mist <= iocontrol.0.coolant-mist net coolant-flood <= iocontrol.0.coolant-flood # ---probe signal--- net probe-in => motion.probe-input # ---motion control signals--- net in-position <= motion.in-position net machine-is-enabled <= motion.motion-enabled # ---digital in / out signals--- # ---estop signals--- net estop-out <= iocontrol.0.user-enable-out net estop-ext => iocontrol.0.emc-enable-in # ---manual tool change signals--- loadusr -W hal_manualtoolchange net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared # If your MPG outputs a quadrature signal per click set x4 to 1 # If your MPG puts out 1 pulse per click set x4 to 0 setp encoder.0.x4-mode 0 # For velocity mode, set to 1 # In velocity mode the axis stops when the dial is stopped # even if that means the commanded motion is not completed, # For position mode (the default), set to 0 # In position mode the axis will move exactly jog-scale # units for each count, regardless of how long that might take, setp axis.x.jog-vel-mode 0 setp axis.y.jog-vel-mode 0 setp axis.z.jog-vel-mode 0 # This sets the scale that will be used based on the input to the mux4 setp mux4.0.in0 0.1 setp mux4.0.in1 0.01 setp mux4.0.in2 0.001 # The inputs to the mux4 component net scale1 mux4.0.sel0 <= hm2_7i76e.0.7i76.0.0.input-10 net scale2 mux4.0.sel1 <= hm2_7i76e.0.7i76.0.0.input-11 # The output from the mux4 is sent to each axis jog scale net mpg-scale <= mux4.0.out net mpg-scale => axis.x.jog-scale net mpg-scale => axis.y.jog-scale net mpg-scale => axis.z.jog-scale # The MPG inputs net mpg-a encoder.0.phase-A <= hm2_7i76e.0.7i76.0.0.input-16 net mpg-b encoder.0.phase-B <= hm2_7i76e.0.7i76.0.0.input-17 # The Axis select inputs net mpg-x axis.x.jog-enable <= hm2_7i76e.0.7i76.0.0.input-07 net mpg-y axis.y.jog-enable <= hm2_7i76e.0.7i76.0.0.input-08 net mpg-z axis.z.jog-enable <= hm2_7i76e.0.7i76.0.0.input-09 # The encoder output counts to the axis. Only the selected axis will move. net encoder-counts <= encoder.0.counts net encoder-counts => axis.x.jog-counts net encoder-counts => axis.y.jog-counts net encoder-counts => axis.z.jog-counts
5 years 11 months ago #188382 by Becksvill
Replied by Becksvill on topic HAL setup for MPG Pendant
did you sort this? i got the same mpg working with a 7i76 mesa card and can send you the hal file if you want
Andrew
5 years 11 months ago - 5 years 11 months ago #188386 by bevins
Replied by bevins on topic HAL setup for MPG Pendant
First, Check and see if your pins are working.
Do you have the correct mode set in the hal file for using the encoder pins? Does your encoder pins show up in"Show Hal Configuration"?
This is a working config for that kind of mpg.
Warning: Spoiler!
Last edit: 5 years 11 months ago by bevins.
5 years 11 months ago #188387 by bevins
You may need to install pullups on your encoder pins 16,17.
4 years 4 months ago - 4 years 4 months ago #245043 by Hammerbot
Replied by Hammerbot on topic HAL setup for MPG Pendant
Hey Andrew,
I am working through this same setup. Can I get a copy of your HAL?
Thanks, Tim
Last edit: 4 years 4 months ago by Hammerbot.
Time to create page: 0.544 seconds
