Help with User M Code
  • RobotMatic
  • RobotMatic's Avatar Topic Author
  • Elite Member
  • Elite Member
17 Dec 2020 09:39 - 17 Dec 2020 09:53 #192252 by RobotMatic
Help with User M Code was created by RobotMatic
video
when the program is stopped by emergency or by the ESC button, Linuxcnc turns off the signals M3-M7-M8 for example.
I am using Linuxcnc 2.8 in a 5 axis configuration for a 2 station induction machine where I have created 4 user M codes.
M100 ON Inductor A
M101 OFF Inductor A
M102 ON Inductor B
M103 OFF Inductor B
When I create my special M code, I cannot connect it to any signal, a condition that I must respect for my M code to work.
So, I can't understand how I can make the M codes created run in the same ESC or emergency situation to turn off the inductors.
in my configuration it would be to execute M101-M103
for example
# M100 Encendido Inductor A
halcmd setp parport.0.pin-01-out TRUE
exit 0
Thanks for the help
Last edit: 17 Dec 2020 09:53 by RobotMatic.
17 Dec 2020 11:25 - 17 Dec 2020 11:26 #192264 by Aciera
Replied by Aciera on topic Help with User M Code
Add this to your .ini file:
[HALUI]
MDI_COMMAND = M101 (OFF Inductor A)
MDI_COMMAND = M103 (OFF Inductor B)
Then in your .hal file connect like this as an example:
net inductors-off   <= halui.estop.is−activated  =>  halui.mdi-command-00  =>  halui.mdi-command-01
Last edit: 17 Dec 2020 11:26 by Aciera.
The following user(s) said Thank You: RobotMatic
17 Dec 2020 11:26 #192266 by cmorley
Replied by cmorley on topic Help with User M Code
I think you could use an and2 component.
connect the output to the parallel port pin
connect one input to estop
set the other input from your Mcode file.
Chris
  • RobotMatic
  • Elite Member
  • Elite Member
18 Dec 2020 09:12 #192336 by RobotMatic
Replied by RobotMatic on topic Help with User M Code
Thank you very much for the help, I will be modifying it. I'm learning a lot thanks to the help of this forum !!! thanksssss
Time to create page: 0.846 seconds
