"make not found" when running halcompile
19 Dec 2020 10:02 #192462 by Eric282000
"make not found" when running halcompile was created by Eric282000
i have a lathe running linux cnc 2.7 that works perfectly. i am trying to upgrade to 2.8
i did a fresh install with 2.8 buster iso. moved my config files over and ran the conversion script to convert them.
i installed linuxcnc-uspace-dev and when i run halcompile --install on my .comp files i get "make not found"
not sure where to go from here.
any help would be appreacited.
19 Dec 2020 14:54 #192476 by chris@cnc
Replied by chris@cnc on topic "make not found" when running halcompile
Hi Eric,
Load the build-essential package and try again.
20 Dec 2020 19:37 #192593 by Eric282000
Replied by Eric282000 on topic "make not found" when running halcompile
Chris,
Thanks I will try this when I get back home.
Time to create page: 0.119 seconds
