Load components in hal
- Profed81
- Visitor
30 Dec 2020 20:05 #193601
by Profed81
Load components in hal was created by Profed81
Hello
Ask,
to install a component in a sample configuration of the configuration selector, you should write only, for example "load rt stepgen
The point is that I need to add engines to a simulation example that does not have stepgen loaded and does not have pwm either.
I only need to write "load rt pwm" inside the hal folder? or should I write it from the bash terminal?
Ask,
- Thank you received: 7504
31 Dec 2020 17:14 #193689
Replied by tommylight on topic Load components in hal
This is the second time i am reading this, but can not understand what the question is due to translation.
Can you also post the question on your native language, maybe a member here can help translate it better.
Time to create page: 0.440 seconds
