XHC-WHB04B-6 Help needed
5 years 9 months ago - 5 years 9 months ago #194976 by alkabal
Replied by alkabal on topic XHC-WHB04B-6 Help needed
Did you use a buildbot instal or a run in place ?
All the error i see in your picture is signal already linked so you need to found solution for unconnect this signal from other place
Last edit: 5 years 9 months ago by alkabal.
5 years 9 months ago #194977 by ChrissyAG
Replied by ChrissyAG on topic XHC-WHB04B-6 Help needed
sorry, I only saw half of your reply when I hit send on my previous reply.
I will now check the pendant file and reset it to it's original state and follow your additional suggestions and report back when I have run it again.
I don't have skype but I could set it up if that is easier. (I would need to get a webcam).
5 years 9 months ago - 5 years 9 months ago #194981 by alkabal
alkabal wrote: Did you use a buildbot install or a run in place ?
If you use run in place (compiling linuxcnc yourself) a file need a copy past in rules folders ! (no need if you install from apt-get)
sudo cp /home/pi/emc/debian/extras/lib/udev/rules.d/*.* /etc/udev/rules.d
The following user(s) said Thank You: vre
5 years 9 months ago #194986 by ChrissyAG
SUCCESS!!!!!!!!
I went back to the pendant file ie the one I posted most recently and then simply changed:
#net machine.is-on halui.machine.is-on whb.halui.machine.is-on
to:
saved the file and started LinuxCNC to check and WOOOHOOO! I have encoder counts!
I cannot thank you enough, this has been a very steep learning curve so far, but the pendant was the thing that really tripped me up.
I'm sure this is not the last issue I will have with configuring LinuxCNC on my machine, but at least I feel confident to go forwards and get the rest of it sorted. Especially knowing that the expertise is only a message away.
Thank you so much. You have literally saved my project.
5 years 4 weeks ago - 5 years 4 weeks ago #222077 by jurod
Replied by jurod on topic XHC-WHB04B-6 Help needed
Hi, is it possible to somehow change the sense of turning the wheel when jogging?
Example:
select axis A =>
wheel rotate to +
but i need axis A rotate to -
Last edit: 5 years 4 weeks ago by jurod.
5 years 4 weeks ago - 5 years 4 weeks ago #222221 by alkabal
Hi
Maybee using this component :
github.com/robEllenberg/linuxcnc-mirror/...mponents/invert.comp
loadrt invert    names=invert.a
addf invert.a    servo-thread
net pdnt-axis.A.jog-counts    whb.axis.a.jog-counts    invert.a.in
net pdnt-axis.A.jog-counts-inverted     invert.a.out     axis.a.jog-counts
totaly untested
Br
Last edit: 5 years 4 weeks ago by alkabal.
Time to create page: 0.159 seconds
