XHC-WHB04B-6 Help needed
5 years 3 weeks ago #222265 by jurod
Replied by jurod on topic XHC-WHB04B-6 Help needed
 net pdnt-axis.A.jog-counts    whb.axis.a.jog-counts    invert.a.in
net pdnt-axis.A.jog-counts-inverted     invert.a.out     axis.a.jog-counts
Error. The jog-counts is type s32 and component Invert is type float.
The following example works, but with a feature:
net pdnt-axis.A.jog-counts    whb.axis.a.jog-scale    invert.a.in
net pdnt-axis.A.jog-counts-inverted     invert.a.out     axis.a.jog-scale
Selective incremental wheel
0.001 => 5
0.01 => 1
0.1 => 0.1
1 => 0.01
5 => 0.001
4 years 11 months ago #225833 by roland206
Replied by roland206 on topic XHC-WHB04B-6 Help needed
I just read your chat regarding your XHC-WHB issue. You solved the problem and wrote "SUCCESS!!!!!!!!". I don't undestand what you changed. I have the same (or similar) problem and don't know how to solve it.
2 years 8 months ago - 2 years 8 months ago #292930 by vre
Replied by vre on topic XHC-WHB04B-6 Help needed
Hello.
I have debian 12 /  linuxcnc 2.10pre master and XHC-WHB04B-6 doesn't work
I had copied udev rules but seems that doesn't work because if i run this command as root
xhc-whb04b-6 -ue works fine but doesn't work if i run it as user.
My udev rules file
cat /etc/udev/rules.d/99-xhc-whb04b-6.rules
# xhc-whb04b-6 mpg pendant SUBSYSTEM=="usb", ATTR{idProduct}=="eb93", ATTR{idVendor}=="10ce", MODE="600", TAG+="uaccess"
update ---
solved by adding to udev rules
ATTRS{idVendor}=="10ce", ATTRS{idProduct}=="eb93", MODE="666", OWNER="root", GROUP="users"
Last edit: 2 years 8 months ago by vre.
Time to create page: 0.129 seconds
