PS4 help
06 Feb 2021 15:27 #197872 by Tady
PS4 help was created by Tady
Hello
I'm trying to connect my PS4 controller to LinuxCNC with HAL_Input
less /proc/bus/input/devices
gives me ...
I: Bus=0005 Vendor=054c Product=09cc Version=8100
N: Name="Wireless Controller Touchpad"
P: Phys=e0:2a:82:d4:4a:3e
S: Sysfs=/devices/pci0000:00/0000:00:13.0/usb5/5-2/5-2:1.0/bluetooth/hci0/hci0:11/0005:054C:09CC.0003/input/input17
U: Uniq=1c:a0:b8:86:b3:3a
H: Handlers=mouse2 event14
B: PROP=5
B: EV=b
B: KEY=2420 10000 0 0 0 0
B: ABS=260800000000003
N: Name="Wireless Controller Motion Sensors"
S: Sysfs=/devices/pci0000:00/0000:00:13.0/usb5/5-2/5-2:1.0/bluetooth/hci0/hci0:11/0005:054C:09CC.0003/input/input18
H: Handlers=event15
B: PROP=40
B: EV=19
B: ABS=3f
B: MSC=20
N: Name="Wireless Controller"
S: Sysfs=/devices/pci0000:00/0000:00:13.0/usb5/5-2/5-2:1.0/bluetooth/hci0/hci0:11/0005:054C:09CC.0003/input/input16
H: Handlers=event16 js1
B: PROP=0
B: EV=20001b
B: KEY=7fdb000000000000 0 0 0 0
B: ABS=3003f
B: MSC=10
B: FF=107030000 0
The last entry is the one I need. But if I use
loadusr -W hal_input -KRAL Controller
HAL selects the first found entry
The one that works currently is
loadusr -W hal_input -KRAL 16
But that can change during reboots
I did find a section in the documentation that should work by specifying a number
:N
But I don't know how to correctly use it
Also in some examples people use stings with spaces in between
loadusr -W hal_input -KRAL Wireless Controller
But it seems only the last string is valid?
Thank you
08 Feb 2021 17:50 #198099 by andypugh
Replied by andypugh on topic PS4 help
I _think_ you can use any word in the name, so try "Motion" or "Sensors"
09 Feb 2021 00:39 #198121 by Tady
Replied by Tady on topic PS4 help
The thing is that Sony made stupid naming.. The last entry is the correct one and if you take a look it only says Wireless controller
The first two use the sam string.. So if I use wireless or controller Hal_input always picks the first entry.
That is why I am asking on how to select the third option.
For now I am using the event number. But that can change on reboots
09 Feb 2021 03:03 - 09 Feb 2021 03:03 #198129 by andypugh
Sorry, I hadn't realised that there were three entries in the code box.
I wonder if this will work?
loadusr -WN temp -KRAL "Controller"
loadusr -WN temp2 -KRAL "Controller"
loadusr -WN joypad -KRAL "Controller"
unload temp
unload temp2
I have tried to find out if there is a way to force an exact match, but I haven't even managed to find out where linux_event is from. (in the hal_input source code)
Does the event number _actually_ change with a reboot? One solution if it does might be to have a small Python wrapper programme that looks through /dev for an exact name match, extracts the event number and loads the component by number.
Last edit: 09 Feb 2021 03:03 by andypugh.
09 Feb 2021 13:13 #198185 by Tady
Throws
Loadusr: invalid option - - 'N'
09 Feb 2021 14:56 #198200 by andypugh
10 Feb 2021 13:28 #198315 by Tady
Nope throws an error
loadusr -Wn temp -KRAL Controller
loadusr -Wn temp2 -KRAL Controller
unload temp
unload temp2
loadusr: invalid option -- 'K'
I'm using 2.9 and I really don't understand temp and temp2.. Are these components in LinuxCNC?
10 Feb 2021 13:57 #198319 by andypugh
You can load a component with a custom name.
What I am trying to do is to load the component three times, then unload the first two, hopefully leaving the one that you want.
I think I see where it is going wrong, I forgot to tell the system _what_ to load.
loadusr -Wn temp hal_input -KRAL Controller
loadusr -Wn temp2 hal_input -KRAL Controller
loadusr -Wn keep_me hal_input -KRAL Controller
unload temp
unload temp2
11 Feb 2021 08:28 #198399 by Tady
Now it complains. Waiting for component temp to become ready
If I remove - W it throws another error. It doesn't like it without the W
11 Feb 2021 08:43 - 11 Feb 2021 08:44 #198403 by andypugh
Does it get bored of waiting? Some wait is to be expected.
You might have to expand any udev changes to include the other devices.
What _are_ the other devices?
Last edit: 11 Feb 2021 08:44 by andypugh.
Time to create page: 0.751 seconds
