Considerations on Microsoft X-Box360 pad
  • sibelius
  • sibelius's Avatar Topic Author
  • Visitor
  • Visitor
25 Feb 2021 05:16 - 25 Feb 2021 05:17 #200081 by sibelius
Good evening everybody
I am trying to setup the pad control.
The first way I did, i just use the tool QJoyPad and it works.
The second way I followed the wiki and it does not work properly.
I think the problem is in this piece of code (I have axis 0,1,2,3)
net jog-x-analog <= input.0.abs-x-position => halui.joint.0.analog halui.axis.x.analog
net jog-y-analog <= input.0.abs-y-position => halui.joint.1.analog halui.axis.y.analog
net jog-z-analog <= input.0.abs-ry-position => halui.joint.3.analog halui.axis.z.analog
What I am trying to say is that linuxcnc is opening without errors but when i try to jog X for example Z goes too.
I have X and Y on one analog stick and Z in the other analog stick.
I have tried to follow the second way due to the fact that the two analog sticks are sensitive behind any control.
I am going to attach my hal files if someone like to have a look.
Thanks in advance for any help
Regards,
V.
Last edit: 25 Feb 2021 05:17 by sibelius.
  • sibelius
  • Visitor
  • Visitor
25 Feb 2021 22:41 #200173 by sibelius
Replied by sibelius on topic Considerations on Microsoft X-Box360 pad
Good afternoon everyone
I manage to sort things out.
Everything is working.
The two analog control still quite sensitive.
I am going to attach the hal file for this specific controller, just in case someone need it
Regards,
V.
Time to create page: 0.189 seconds
