hal >> keypress emulation
- robertspark
- Thank you received: 216
15 Mar 2021 20:44 #202407
by robertspark
hal >> keypress emulation was created by robertspark
is there a way built in within the hal to emulate a keypress?
I am aware of this python library which could be easily used / integrated as a new component, but was wondering if there was something else already available (i'd hate to reinvent the wheel.....)
pypi.org/project/keyboard/
thanks in advance
Please note I have a serial keypad that I'd like to be able to set up a couple of keys to be able to type Gcode into the mdi, yes I know I can use a bog standard keyboard, but I was wondering if there was another way via hal that this could be integrated with this serial device.
Rob
thanks in advance
Rob
- Thank you received: 4648
17 Mar 2021 13:55 #202598
Yes, the "sendkeys" compoent can do this.
linuxcnc.org/docs/devel/html/man/man1/sendkeys.1.html
Replied by andypugh on topic hal >> keypress emulation
The following user(s) said Thank You: nkp, robertspark
Time to create page: 0.114 seconds
