Python Component issueing errors or warnings to LinuxCNC
- mwinterm
- Thank you received: 13
23 Apr 2021 10:15 #206878
by mwinterm
Python Component issueing errors or warnings to LinuxCNC was created by mwinterm
Hello,
I have the hopefully trivial questions how to issue errors and warnings from a Python component?
Best regards,
Marc
Best regards,
Marc
- Thank you received: 2181
23 Apr 2021 16:51 #206891
Replied by cmorley on topic Python Component issueing errors or warnings to LinuxCNC
Would need more info.
Usually errors are shown with dialogs or printed in the terminal
But your question is vague.
What errors? Linxcnc's ?....the programs's ?
Are you using a GUI library or do you just want to print to the terminal to debug?
If you wish to display linuxcnc errors - it can be tricky and depends on what (if) screen is also being used.
- mwinterm
24 Apr 2021 04:46 #206940
by mwinterm
Replied by mwinterm on topic Python Component issueing errors or warnings to LinuxCNC
I would like to display an LinuxCNC error. When I do this out of a remap.py and can do it with e.g.
and then use
and it pops up in LinuxCNC (Axis GUI and GMOCCAPY).
Even though I'm also there missing how to specify something like a message level to define if it is just a message, warning, error....
I would like to do the same from Python component.
from emccanon import MESSAGEand then use
MESSAGE("This is my message")and it pops up in LinuxCNC (Axis GUI and GMOCCAPY).
24 Apr 2021 16:24 #206969
unfortunately that library is unavailable outside of remap code.
I know of no other way to send a user message through linuxcnc's error channel.
I worked around this problem in qtvcp by sending linuxcnc's error messages through GObject messages so i could add my own messages.
But this is screen dependent and cannot be done with multiple python programs on the same system.
I think the error system in linuxcnc could use a re-think specifically for there problems.
the easiest thing to do is pop your own messag dialogs.
GMoccapy, gscreen and qtvcp can pop messages controlled by HAL pins.
It does mean the messages can't change after start up.
Or you can build your own dialog in your python code.
Chris
Chris
- mwinterm
25 Apr 2021 12:41 #207034
by mwinterm
Thank you Chris. Unfortunately not the easy solution I have hoped for...
Regards,
Marc
Regards,
Marc
- Thank you received: 4656
29 Apr 2021 03:40 #207356
Replied by andypugh on topic Python Component issueing errors or warnings to LinuxCNC
This is inelegant, but I think that you could MDI a magic G-code comment.
If you wanted to halt execution with an error:
There are limitations on MDI:
linuxcnc.org/docs/2.8/html/config/python...ing_to_send_commands
c.mdi("(ABORT, Out of cheese error)")There are limitations on MDI:
29 Apr 2021 09:24 #207377
We should create a NML message command for this purpose that can be send from python's linuxcnc module. I wonder how hard that would be.
- Roiki
- Thank you received: 19
30 Apr 2021 08:33 #207452
by Roiki
Replied by Roiki on topic Python Component issueing errors or warnings to LinuxCNC
Afaik it already exists, it's just not included in the python module.
30 Apr 2021 09:27 #207458
What makes you say that?
01 May 2021 16:50 #207577
There do seem to be messages:
github.com/LinuxCNC/linuxcnc/blob/2e75b0..._intf/emc_nml.hh#L33
And emcmodule seems to read them, but not write them?
github.com/LinuxCNC/linuxcnc/blob/2e75b0...s/emcmodule.cc#L1496
Time to create page: 0.151 seconds
