Halsampler tools
09 Apr 2022 11:27 #239749 by turbostew
Replied by turbostew on topic Halsampler tools
rgb,
I'm not so great with Git. I can just post the file here if you are OK with that.
09 Apr 2022 14:00 #239769 by rgb
Replied by rgb on topic Halsampler tools
Yes, that's fine, thanks.
11 Apr 2022 10:21 - 11 Apr 2022 10:41 #239925 by turbostew
Here is my heavy modified version...... This module does not have the display all fields if no fields specified feature.  It does xy plots and has sample delay option.  You can also hide a field, this is so you can use the field (with scaling/samp delay) for x values in xy plot without the field also being plotted on a time scale.
Last edit: 11 Apr 2022 10:41 by turbostew.
12 Apr 2022 12:58 #240064 by rgb
Thanks! I'll take a look at your changes.
Bob
16 Apr 2022 16:27 #240426 by rgb
Thanks for the code @trubostew. I liked your idea of doing the options work in the numpy array rather than trying to do it all in the main loop. The change simplified the option processing. I added your delay option as well. My new version is in github now.
27 Apr 2022 16:08 #241403 by turbostew
Glad my code was usefull.  Thanks!
Time to create page: 0.167 seconds
