HAL Pin(s) for Jogging with a Button
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
04 Jul 2021 12:14 #213705 by BigJohnT
HAL Pin(s) for Jogging with a Button was created by BigJohnT
Using 2.8.2 and trying to sort out what pin(s) I need to use to jog the X axis plus or minus direction. Anyone have a snippet from a working config?
JT
04 Jul 2021 12:31 - 04 Jul 2021 12:46 #213707 by Aciera
Replied by Aciera on topic HAL Pin(s) for Jogging with a Button
I use this with master but I think it's the same in 2.8.2
# --- panel jog buttons
net x-plus-panel => halui.axis.x.plus
net x-minus-panel => halui.axis.x.minus
Note that to be able to jog in JOINT mode you will need to also connect:
halui.joint.N.minus bit inpin for jogging joint N in negative direction at the halui.joint.jog-speed velocity
halui.joint.N.plus bit inpin for jogging joint N in positive direction at the halui.joint.jog-speed velocity
Last edit: 04 Jul 2021 12:46 by Aciera. Reason: This new editor has a mind of it's own
The following user(s) said Thank You: BigJohnT, arvidb
Time to create page: 0.156 seconds
