changing Hal parameters
- anfänger
- Thank you received: 271
10 Jul 2021 14:21 #214210
by anfänger
changing Hal parameters was created by anfänger
I use a bash script for gear change and was kind of lazy. I have 12 manual selectable gears and a two clutches (1.1 and 1:1.6 gear reduction) I can use. So it is more or less a two stage gearbox. I use one gear change module for the clutches and set the parameters with a bash script / MCode. In Hal everything looks fine the parameters are changed. BUT when I tested it with the machine running it looks like the initial parameters are used.
For example on startup the min_speed_2 parameter is set to 1600 I change gear and the in Halshow min_speed_2 parameter is now 72 as it should be for this gear when I try to run the spindle now at 80 rpm the output is still 1600
is there a way to get the parameters updated or a neat way to work with a two stage gearbox?
thanks Patrick
thanks Patrick
- Thank you received: 2177
11 Jul 2021 01:17 #214230
Replied by Aciera on topic changing Hal parameters
Can you post your script / MCode?
- anfänger
11 Jul 2021 01:52 - 11 Jul 2021 01:55 #214234
by anfänger
Replied by anfänger on topic changing Hal parameters
yea sure this is the script where I change the parameters. In Halshow I see that they are updated but the module still works with the initial parameters.
#!/bin/sh
#set clutch 2
P=$1
Q=$2
gearnr=${P%.*}
echo $gearnr
if [ $gearnr = 1 ]; then
# set -- $(halcmd -s getp gearchange.0.max1)
max=1400
halcmd setp gearchange.0.max1 $max
acc=1400
halcmd setp gearchange.0.acc1 $acc
min=1000
halcmd setp gearchange.0.min1 $min
scale=1.6
halcmd setp gearchange.0.scale1 $scale
max=$(echo "$max*1.6" | bc)
halcmd setp gearchange.0.max2 $max
acc=$(echo "$acc*1.6" | bc)
halcmd setp gearchange.0.acc2 $acc
min=$(echo "$min*1.6" | bc)
halcmd setp gearchange.0.min2 $min
scale=$(echo "scale=5; $scale/1.6" | bc)
halcmd setp gearchange.0.scale2 $scale
fi
if [ $gearnr = 2 ]; then
max=500
acc=500
min=357
scale=4.48
fi
if [ $gearnr = 3 ]; then
max=710
acc=710
min=507
scale=3.15493
fi
if [ $gearnr = 4 ]; then
max=1000
acc=1000
min=714
scale=2.24
fi
if [ $gearnr = 5 ]; then
max=355
acc=355
min=253
scale=6.309859
fi
if [ $gearnr = 6 ]; then
max=128
acc=128
min=91
scale=17.5
fi
if [ $gearnr = 7 ]; then
max=180
acc=180
min=128
scale=12.44444
fi
if [ $gearnr = 8 ]; then
max=250
acc=250
min=178
scale=8.96
fi
if [ $gearnr = 9 ]; then
max=80
acc=80
min=57
scale=28
fi
if [ $gearnr = 10 ]; then
max=31.5
acc=31.5
min=22
scale=71.11111
fi
if [ $gearnr = 11 ]; then
max=45
acc=45
min=32
scale=49.77778
fi
if [ $gearnr = 12 ]; then
max=63
acc=63
min=45
scale=35.55556
fi
exit 0
Last edit: 11 Jul 2021 01:55 by anfänger.
- anfänger
11 Jul 2021 11:07 #214278
by anfänger
I took the long route and set up all 24 gears in gear change and changed my M codes.
11 Jul 2021 12:30 #214299
It's a long shot but sometimes a forced synch helps:
M66 E0 L0
M66 E0 L0
- Grotius
- Thank you received: 2349
11 Jul 2021 17:09 - 11 Jul 2021 17:12 #214330
by Grotius
Replied by Grotius on topic changing Hal parameters
If your module isn't updating, maybe create a thread.
halcmd loadrt threads name1=gear-thread
halcmd loadrt yourgearmodule
halcmd addf update gear-thread
Then in your component add function declaration:
static void update();
Add function eof:
// here your code to update or initialize the values.
If you don't know how to. Then you can post your component source file.
Add function eof:
Last edit: 11 Jul 2021 17:12 by Grotius.
The following user(s) said Thank You: anfänger
Time to create page: 0.265 seconds
