Comment Block of text in HAL File;
5 years 2 months ago #218171 by C_M_H
Hello,
Is it possible to comment entire blocks of text in a HAL file?
In the AVR assembler I use you can specify /* at the head and */ at the tail of a block of text. The assembler and my text editor recognize anything in between as a comment and ignores it. This helps me "turn-off" chunks of code easily when troubleshooting.
Are there equivalent characters that will the same with a HAL file?
Thanks,
Craig
Example of assembly file with bracketed comment;
5 years 2 months ago #218198 by cmorley
No block comments in HAL.
5 years 2 months ago #218257 by C_M_H
Ok, thanks for the reply.
Time to create page: 0.046 seconds
