I can't get spindle speed feedback
4 years 10 months ago - 4 years 10 months ago #229885 by Servimet
File Name: shutdown.hal
File Size:111 B
File Name: postgui_call_list.hal
File Size:102 B
File Name: Sabre_1000...2-24.hal
File Size:14.84 KB
Attachment not found
Last edit: 4 years 10 months ago by Servimet.
4 years 10 months ago #229886 by Servimet
Hi Hakan, this is the moment, I'm editing the file extension to be able to upload it to the forum. I would appreciate your help in a review.
4 years 10 months ago #229887 by Servimet
Hello Clive S, this time I am editing the extension of the configuration files to be able to upload it all to the forum
4 years 10 months ago - 4 years 10 months ago #229889 by Clive S
Is it correct that the only file Sabre_1000_2021-12-24.hal is the only one with any data in it.
It might be better to zip the complete config up.
Can you also give a description of the machine ie. how many axis XYZ does  it have a A axis
as the HAL file seems to have a few duplications
The ini file is missing as well.
Last edit: 4 years 10 months ago by Clive S.
4 years 10 months ago - 4 years 10 months ago #229894 by Servimet
hello Clive S the only files that contain data are:
sabre_1000.ini
sabre_1000.hal
sabre_1000.ini.bak
position.txt
linuxcnc.var
The machine is:
Cincinatti sabre 1000 4 axis
thank you very much for the great help
4 years 10 months ago - 4 years 10 months ago #229896 by Servimet
Clive s
attachment in another missing file with data
sabre_1000.ini.bak
[EMC]
# The version string for this INI file.
VERSION = 1.1
MACHINE = CINCINNATI
DEBUG = 0
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0 = hm2_eth
# BOARD0 = 7i92
# BOARD1 = 7i77
[DISPLAY]
DISPLAY = gmoccapy
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/cnc/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 6.000000
MAX_LINEAR_VELOCITY = 167.000000
MIN_LINEAR_VELOCITY = 0.500000
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = XYZA
[MACROS]
MACRO = parking
MACRO = spin_warm
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
SUBROUTINE_PATH = macros
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[HAL]
HALUI = halui
HALFILE = Sabre_1000.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[TRAJ]
COORDINATES = X Y Z A
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 2.50
MAX_LINEAR_VELOCITY = 25.00
NO_FORCE_HOMING = 1
POSITION_FILE = position.txt
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[KINS]
KINEMATICS = trivkins coordinates=XYZA
JOINTS = 4
[AXIS_X]
# Axis X
MIN_LIMIT = -1500.0
MAX_LIMIT = 0.01
MAX_VELOCITY = 167.0
MAX_ACCELERATION = 750.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 2.0
MIN_FERROR = 1.0
P = 2.5
I = 0
D = 0
FF0 = 0
FF1 = 0.01
FF2 = 0
BIAS = 0
DEADBAND = 0.5
MAX_OUTPUT = 10
ENCODER_SCALE = -1000
OUTPUT_SCALE = 10
OUTPUT_MIN_LIMIT = -10
OUTPUT_MAX_LIMIT = 10
MIN_LIMIT = -1500.0
MAX_LIMIT = 0.01
HOME_OFFSET = 0
HOME_SEQUENCE = 1
HOME_SEARCH_VEL = 5.0
HOME_LATCH_VEL = 2.5
[AXIS_Y]
# Axis Y
MIN_LIMIT = -1500.0
MAX_LIMIT = 0.01
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 2.0
MIN_FERROR = 1.0
P = 2.5
I = 0
D = 0
FF0 = 0
FF1 = 0.01
FF2 = 0
BIAS = 0
DEADBAND = 0.5
MAX_OUTPUT = 10
OUTPUT_SCALE = 10
MIN_LIMIT = -1500.0
MAX_LIMIT = 0.01
HOME_OFFSET = 0
HOME_SEQUENCE = 1
[AXIS_Z]
# Axis Z
MIN_LIMIT = -1500.0
MAX_LIMIT = 0.01
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 2.0
MIN_FERROR = 1.0
P = 2.5
I = 0
D = 0
FF0 = 0
FF1 = 0.01
FF2 = 0
BIAS = 0
DEADBAND = 0.5
MAX_OUTPUT = 10
OUTPUT_SCALE = 10
MIN_LIMIT = -1500.0
MAX_LIMIT = 0.01
HOME_OFFSET = 0
HOME_SEQUENCE = 1
# Axis A
[AXIS_A]
MIN_LIMIT = -1e+15
MAX_LIMIT = 1e+15
[JOINT_3]
TYPE = ANGULAR
HOME = 0.0
FERROR = 2.0
MIN_FERROR = 1.0
P = 2.5
I = 0
D = 0
FF0 = 0
FF1 = 0.01
FF2 = 0
BIAS = 0
DEADBAND = 0.5
MAX_OUTPUT = 10
ENCODER_SCALE = -4000
OUTPUT_SCALE = 10
MIN_LIMIT = -1e+15
MAX_LIMIT = 1e+15
HOME_OFFSET = 0
HOME_SEQUENCE = 1
[SPINDLE_9]
# Spindle
P = 1
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 8000
ENCODER_SCALE = 1000.0
OUTPUT_SCALE = 10
OUTPUT_MIN_LIMIT = 0
OUTPUT_MAX_LIMIT = 8000
Time to create page: 0.195 seconds
