Momentary buttons to set one pin value
  • AgentWD40
  • AgentWD40's Avatar Topic Author
  • Platinum Member
  • Platinum Member
04 Jan 2022 23:14 - 04 Jan 2022 23:21 #230827 by AgentWD40
Momentary buttons to set one pin value was created by AgentWD40
My game controller pendant has 4 momentary buttons x, y, a, and b. I would like to assign a value to each of these buttons and each time a button is pressed I’d like to set a pin’s value to the pressed button’s assigned value. I’d like this pins value to persist after the momentary buttons are released and until the next button press overwrites it. Ideas?
This seems like it should be very straight forward but I’m still learning hal and am not seeing any components that fit the bill in the docs. I’m tempted to just write one but really don’t want to if I don’t have to.
Last edit: 04 Jan 2022 23:21 by AgentWD40.
05 Jan 2022 01:08 #230837 by rodw
The following user(s) said Thank You: AgentWD40
  • AgentWD40
  • Platinum Member
  • Platinum Member
05 Jan 2022 06:43 - 05 Jan 2022 06:44 #230861 by AgentWD40
Replied by AgentWD40 on topic Momentary buttons to set one pin value
I saw that one but I'm not sure how it would be implemented. Can you show me how one might configure so that toggling one button on would toggle three others off? At the same time toggling one off should not toggle the others on.
Last edit: 05 Jan 2022 06:44 by AgentWD40.
  • AgentWD40
  • Platinum Member
  • Platinum Member
05 Jan 2022 10:33 #230875 by AgentWD40
I whipped up a python component that accomplishes what I'm after.
My first question is can I accomplish the same thing with standard components?
My second question is for something like this what is an appropriate sleep time?
#!/usr/bin/env python3
import hal, time
h = hal.component("select4")
h.newpin("in0", hal.HAL_FLOAT, hal.HAL_IN)
h.newpin("in1", hal.HAL_FLOAT, hal.HAL_IN)
h.newpin("in2", hal.HAL_FLOAT, hal.HAL_IN)
h.newpin("in3", hal.HAL_FLOAT, hal.HAL_IN)
h.newpin("sel0", hal.HAL_BIT, hal.HAL_IN)
h.newpin("sel1", hal.HAL_BIT, hal.HAL_IN)
h.newpin("sel2", hal.HAL_BIT, hal.HAL_IN)
h.newpin("sel3", hal.HAL_BIT, hal.HAL_IN)
h.newpin("out", hal.HAL_FLOAT, hal.HAL_OUT)
h.ready()
last_selection = 'in0'
try:
    while 1:
        time.sleep(0.005)
        if h['sel0']:
        elif h['sel1']:
            last_selection = 'in1'
        elif h['sel2']:
            last_selection = 'in2'
        elif h['sel3']:
            last_selection = 'in3'
        h['out'] = h[last_selection]
except KeyboardInterrupt:
	raise SystemExit
Time to create page: 0.076 seconds
