Problems with Vista CNC pendent
- milu
18 Jan 2022 22:48 - 18 Jan 2022 22:49 #232398
by milu
Problems with Vista CNC pendent was created by milu
After upgrading to 2.9 (because I have to), I discovered that I can't get my spindle to operate. Not only does the pendent not work for that function, but G3 from the manual input line has no effect. The hal file for my mill is called xyz.hal and includes this line:
xyz.hal:net spindle-on => parport.0.pin-01-out
And the pendent hal includes the following:vc-p4s.hal:net spindle.is-on halui.spindle.0.is-on => vc-p4s.spindle.is-on =11pt
I changed xyz.hal to replace "spindle-on" with "spindle.is-on" and now both the pendant and G3/G5 work as expected. Is that the correct fix or is the vista code wrong?
Last edit: 18 Jan 2022 22:49 by milu.
- ALittleOffTheRails
- Visitor
18 Jan 2022 23:48 - 18 Jan 2022 23:50 #232400
by ALittleOffTheRails
Replied by ALittleOffTheRails on topic Problems with Vista CNC pendent
Spindle are M codes
Last edit: 18 Jan 2022 23:50 by ALittleOffTheRails.
- milu
18 Jan 2022 23:55 #232401
by milu
Replied by milu on topic Problems with Vista CNC pendent
Sorry, M3/M5. But same question.
- Visitor
19 Jan 2022 00:47 - 19 Jan 2022 00:49 #232405
Technically if you are trying to match to the vc-ps.hal, your xyz.hal was wrong. On the other hand if you are trying to match your xyz.hal, the vc-ps.hal was wrong.
As long as the signals are the same name you're good to go.
You could have had.And
But it kind of looks silly and hard to read later on.
This will give you a better idea.
linuxcnc.org/docs/master/html/hal/intro.html
You could have had.
vc-p4s.hal:net scarey.turny.thing.on halui.spindle.0.is-on => vc-p4s.spindle.is-onxyz.hal:net scarey.turny.thing.on => parport.0.pin-01-outBut it kind of looks silly and hard to read later on.
Last edit: 19 Jan 2022 00:49 by ALittleOffTheRails.
- milu
19 Jan 2022 00:52 #232406
by milu
the xyz.hal was generated, from scratch by stepconf. It seems really odd that linuxcnc wouldn't be able to operate the spindle using the hal file generated by its own tool. But, its been an odd week.
- Visitor
19 Jan 2022 01:11 #232409
It's more likely whoever created the vista hal file. Was the vista hal file the one from the vistaCNC site ?
- milu
19 Jan 2022 01:37 #232410
by milu
I think its a bug. I just created a second configuration, using stepconf from scratch (no import) without adding the vistaCNC driver code. It does the same thing. The keyboard can jog the table, but the spindle does not respond to g-code.
- Visitor
19 Jan 2022 02:28 - 19 Jan 2022 02:34 #232411
Well if you think you have found a bug raise an issue on the github page.
In saying that you will need to provide more info. At the very least the gui you are using.
How are you formatting the M code to turn on the spindle ?
Usually in a case like this it is common practice to attach the hal & ini files.
Last edit: 19 Jan 2022 02:34 by ALittleOffTheRails.
- Jake
- Thank you received: 10
19 Jan 2022 20:17 #232496
by Jake
Replied by Jake on topic Problems with Vista CNC pendent
Subscribed..... As I have a Vista pendant also.
Time to create page: 0.098 seconds
