So if anyone else runs across this problem with an RS485 dongle and mb2hal, likely your files are all fine, the problem turned out to be with Debian 12 not adding the user to the group dialout (or requiring dialout to use /dev/ttyUSB0). Found coincidentally in this mail thread:
www.mail-archive.com/emc-users@lists.sou...ge.net/msg91974.html
if stat /dev/ttyUSB0 shows Gid: ( 20/ dialout), run the following:
sudo usermod -a -G dialout $USER
I needed to restart the computer afterwards, likely there is a command to restart some subset and it would have worked, but a fresh restart worked as well.
