Manual tool change Changed pin stays on
- myval
- Thank you received: 7
20 Jan 2022 06:55 #232521
by myval
Manual tool change Changed pin stays on was created by myval
Guys I have another headscratch. I am using qtdragon with manualtoolchange component and first time after boot everything works fine.
manual tool change to tool 0 - probe. hit cycle start the message pops-up request tool x to be inserted hit external button tool changed (the dialogue does not disappear) machine start (I have to hit ok in the dialogue) .
cycle end, I go to tool tab change to probe tool 0 do the probing, hit cycle start the dialogue pops up but the machine starts immediately the dialogue stays on the screen. It could be a problem with probe in the spindle.
If I look in hal show the manualtoolchange.changed stays on.
Any idea what could be causing it, any steps I am missing?
- myval
20 Jan 2022 07:40 #232522
by myval
Replied by myval on topic Manual tool change Changed pin stays on
Quick update: done more research the problem is actually that the tool change dialogue does not close after the external button is pressed.
when I hit the button the pin in halshow goes high so the input is inputing.
Why does the dialogue stay on? When I hit ok in the dialogue the pin .changed stays on forever.
- Thank you received: 2181
20 Jan 2022 07:55 #232524
Replied by cmorley on topic Manual tool change Changed pin stays on
Can you post your config files?
- myval
20 Jan 2022 08:45 #232531
by myval
here are three relevant files. The manualtoolchange.changed-button is normally output from the python script but I just tried to link it direct to the button and still no go.
20 Jan 2022 16:00 #232556
Looks like it's a problem with qtvcp's tool change dialog not honouring the external change button.
20 Jan 2022 17:00 #232566
I pushed a fix to master for this. Thanks for the report.
Please let me know if that fixes it for you.
Chris
Chris
- myval
25 Jan 2022 05:35 #233052
by myval
I am on it as we speak. Will report back soon.
- myval
25 Jan 2022 05:47 #233054
by myval
Thanks mate, runs like a charm.
Time to create page: 0.223 seconds
