Which HAL-Pin for the aspiration
- mgm
- Thank you received: 13
01 Feb 2022 12:14 #233724
by mgm
Which HAL-Pin for the aspiration was created by mgm
Hy
Which hal pin do you have the aspiration connected to?
I currently have it on the pin
halui.program.is-running
I don't like that so much, because with every automatic movement the relay is switched.
For example, when the cutter is in the park position or when changing tools.
Isn't there another pin that only becomes active during a work program?
- Thank you received: 2177
01 Feb 2022 12:33 #233728
Replied by Aciera on topic Which HAL-Pin for the aspiration
I presume that with 'aspiration' you mean a vacuum system.
If so maybe 'halui.mist.on', 'halui.mist.off' or halui.flood.on', 'halui.flood.off'
More info:
linuxcnc.org/docs/html/man/man1/halui.1.html
More info:
- mgm
01 Feb 2022 12:53 #233731
by mgm
Replied by mgm on topic Which HAL-Pin for the aspiration
No I meant suction , as the suction of wood stick and chips
- Thank you received: 1482
01 Feb 2022 13:02 #233732
Replied by Todd Zuercher on topic Which HAL-Pin for the aspiration
I set up custom M-codes (M111, on M112 off) that setp the state of the halpin for the output that turns the vacuum (table clamping) on/off. I also have a button on the screen using a GladeVCP to control the vacuum. If you are referring to dust collection, our shop has a large centralized system that is always on so there is no need to control it at the machine. Air blast or mist or flood are handeled with M7, M8, and M9. M7 turns on the hal pin "iocontrol.0.coolant-mist", M8 turns on the hal pin "iocontrol.0.coolant-flood", and M9 turns both off. And yet another option is to use M62-M65 to control digital outputs in Hal.
- mgm
02 Feb 2022 06:56 #233795
by mgm
ok thanks
the pin switches only the slider of the suction, the suction itself not!
i have now looked at all the Hal pins again .....
now i put it on the pin: "mist.is-on".
i think i will record the M-code in the head of the program.
