Built in HAL components not working
4 years 9 months ago #233742 by ExcessiveO
I have been compiling linuxcnc and running it in place. When I launch it I cannot open the hal config or calibration windows from the dropdown menu(in Axis). I can however add "loadusr halshow" to the main hal file and it will open that window at the start of the program. I have not been able to figure out how to do the same thing with the calibration window.
The specific error I am getting is that for halshow.tcl or emccalib.tcl permission is denied.
Any idea how to get the calibration window working? I have a ton of tuning to do and I'd rather not need to edit the .ini and restart everything after each change.
4 years 8 months ago #233745 by BigJohnT
How are you launching LinuxCNC from the RIP?
JT
4 years 8 months ago #233752 by ExcessiveO
running ~/linuxcnc-2.8/scripts/linuxcnc in the terminal
4 years 8 months ago - 4 years 8 months ago #233892 by BigJohnT
You have to source the rip environment each time you open a terminal
. ./scripts/rip-environment
For the sake of completeness, here is all the steps
Open a terminal in the installed top most directory.
cd src ./autogen.sh ./configure --with-realtime=uspace
Next compile by typing
make
if realtime behavior and hardware access are required
sudo make setuid
Before running the software, set the environment
cd .. . ./scripts/rip-environment
To run the software type
linuxcnc
JT
Last edit: 4 years 8 months ago by BigJohnT.
3 years 5 months ago #272455 by ExcessiveO
So I finally have the time to get back into this project and I still have the same issue. I ran all the commands you said and got no errors but I still cannot get the calibration window to start. I just get:
TCL error in asynchronous code: ....../emccalib.tcl permission denied
Any other ideas?
3 years 5 months ago #272459 by rodw
DId you do sudo make?
That wont work. Just type make
Time to create page: 0.299 seconds
