Servo Encoder set up issue
19 Feb 2022 09:17 - 20 Feb 2022 08:05 #235328 by rider-83
Servo Encoder set up issue was created by rider-83
CNC Lathe, using AC Servo for spindle motor.
Servo Type: Generic 90ST-M02430 (Sometimes listed as Vevor or Yichuan)
Gearing is 1:1
I'm having some issues with screw cutting and also feed rates, and my attention is drawn to the encoder.
I have since moved away from the homemade encoder assembly that was mounted on the spindle in favour of using the encoder that is a built in part of the servo drive.(I initially believed my home made encoder was the root of the issue, but the problem remains even with the new encoder)
I am collecting Phases A & B, and index Z (Single ended only on all phases)
There may be several issues with my configuration, but one at a time:
If I set the servo encoder to 100 PPR(Via parameter 217 in the servo drive)
and
encoder.0.position-scale to 400 (100x4 Because i'm using Quadrature)
Then if I look at 'encoder.0.position' via HAL Show, and rotate the spindle slowly one turn by hand, then I see not 1.0 but  25.0 instead
and
encoder.0.position-scale to 100 (ignoring Quadrature)
Then if I look at 'encoder.0.position' via HAL Show, and rotate the spindle by hand, then I see  an exact 100
Therefor I have found that If I set the servo encoder to 100
and
encoder.0.position-scale to 10000
Then I see the correct 1.0per turn
What would cause this incorrect  count ?
Last edit: 20 Feb 2022 08:05 by rider-83.
19 Feb 2022 12:52 #235340 by PCW
Replied by PCW on topic Servo Encoder set up issue
That would be 10000 counts/turn so more that a few turns per second = say a few hundred RPM would be the fastest the spindle encoder could be read with a parallel port.
19 Feb 2022 13:30 #235343 by rider-83
Replied by rider-83 on topic Servo Encoder set up issue
It dawned on me later that the original PPR value was 2500 factory default.
4x2500=10000
I'm wondering, if the new value I selected of 100ppr hasn't actually registered and is still 2500.
I've discovered that the actual encoder is 2500, but the driver does some stuff with the signal to select different ppr's at the user port end , I think ?
19 Feb 2022 14:07 - 19 Feb 2022 14:08 #235345 by PCW
The drives encoder resolution should not change (its fixed at 2500 PPR)
The question is: can you change the drives simulated encoder output resolution.
Last edit: 19 Feb 2022 14:08 by PCW.
19 Feb 2022 14:38 #235348 by rider-83
Hmmmm.
The manual isn't very clear, as its one of those Chinese to English types. Plus, its tiny, which doesn't help,as the text isn't very clear.
I was led to believe from the manual, that the ppr is manipulated via a parameter, but perhaps they mean something else by that.
I shall scour through it to see what I can find regarding the output resolution.
20 Feb 2022 08:17 - 20 Feb 2022 08:18 #235386 by rider-83
Success !
I've found some parameters that adjust the 2500ppr. The manual doesn't draw your attention to them or relates them all together when adjusting the PPR, so this is how it was missed.
For those out there with the same type of servo, please note.
PPR is default 2500
Pn217 = 2500
Pn016 = 1 (Freq Division)
Pn017 = 1 (Denominator)
Calculation is Pn217 / (Pn16/Pn17) = PPR
or 2500 / (1/1) = 2500 PPR
Then 2500 x4 = 10,000 Using Quadrature
In my case I require 400 counts in my HAL Scale setting, Therefor:
Pn217 = 2500
Pn016 = 25
Pn017 = 1
Or 2500 / (25/1) = 100
Then 100 x4 =400 (In HAL)
The erratic spindle readings have now settled down dramatically. The tacho on the servo drive now corresponds exactly with 'encoder.0.velocity-rpm'
However, the speed indicated by both readings is slightly below commanded rpm, and fluctuates by around 25rpm, but I believe this may be down to my speed control circuit.
I hope this is useful information to others that have purchased a similar servo drive, and are struggling with the manual.
Last edit: 20 Feb 2022 08:18 by rider-83.
06 Mar 2022 06:21 #236499 by rider-83
I've discovered another issue with my encoder set up.
When running the spindle CW (M3), all is well.
However, when I select CCW (M4), then I loose the 0-10v signal.
I achieve spindle direction change by swapping the 0-10v polarity via a relay.
This system worked perfectly fine until I wired in the servo encoder.
If I remove the wires that supply the 0-10v to the servo drive, and meter across them, then I see the correct readings in either M3 (+ 0-10v) or M4 (- 0-10v).
What I'm seeing is almost like the - 0-10v is being pulled down to zero for some reason.
The phase signals supplied from the servo drive are +A/-A +B/-B & +Z/-Z
But rather than collect these differential signals, I've opted for single sided and collect just +A +B +Z.
According with the manual, I have wired +A , +B , +Z and the GND pins from the servo drive directly to my second LPT port. Phases are connected to pins 10,11 & 12 respectively, and GND to pin 25.
If I pull the DB25 from the LPT/servo drive, then the spindle performs correctly.
I don't seem to be able to see the wood from the trees here. Have I missed something in respect to the direct connect to the LPT port?
06 Mar 2022 08:39 #236507 by tommylight
Replied by tommylight on topic Servo Encoder set up issue
If you are reversing the analog output, it requires reversing encoder scale by putting a - in front of the number.
06 Mar 2022 10:16 #236517 by rider-83
I can try it, but would that physically pull down the signal?
06 Mar 2022 12:47 #236526 by tommylight
No.
I did not get that with the " 0-10v is being pulled down to zero"
