Joypad question:
- dab77
06 Oct 2010 22:22 #4542
by dab77
Joypad question: was created by dab77
Hallo, there's a thing about using joypads, that is not clear to me..
is it possible with emc2 to use only normal buttons and directions, or do also the dynamics directions work?
i mean, is it possible to jog as fast as i press the joystick? , or is it only on/off?
thanks, Davide.
thanks, Davide.
- BigJohnT
- Thank you received: 1176
06 Oct 2010 22:58 #4544
by BigJohnT
Replied by BigJohnT on topic Re:Joypad question:
If the joystick output is analog then the yes the jog is proportional to the joystick angle from 0 to 1 I think most are.
- dab77
06 Oct 2010 23:39 #4547
by dab77
Replied by dab77 on topic Re:Joypad question:
thanks John, and does it works both in joint and world mode? and does the joypad need something like calibration?
after that i swear, i'm not going to ask more, before trying to setup a working joypad!
- Rick G
- Thank you received: 155
07 Oct 2010 10:46 #4554
by Rick G
Replied by Rick G on topic Re:Joypad question:
I assume you are using this ...
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Simple_Remote_Pendant
You do not need to do any calibration, the proportional speeds are set in your hal file to what works for your machine.
You can then go on to program different buttons for different functions.
Rick G
Rick G
- BigJohnT
07 Oct 2010 12:37 #4559
by BigJohnT
I don't have a clue about joint or world modes... and ask all the questions you need to.
- step4linux
- Thank you received: 5
07 Oct 2010 15:38 #4566
by step4linux
Replied by step4linux on topic Re:Joypad question:
dab77 wrote:
There are some limitations generally for jogging in world mode, at least they were there in 2.3 for U V W axes.
I'm not aware of limitations specifically using a joypad, but I never used one.
Gerd
Gerd
- dab77
07 Oct 2010 18:51 #4571
by dab77
ok! i would like to use it for my inverted tetrapod, so i need first to jog the 4 single joints (dynamically would be better) and then change to world mode and jog the XYZ position, dynamically, so i think i will need that two joypad axis will jog X and Y, and to use another joypad axis to control Z at the same time.
can you confirm that it can work this way?
thanks, davide.
thanks, davide.
- Rick G
08 Oct 2010 11:07 #4585
by Rick G
Take a look here...
www.cnczone.com/forums/emc_linux_enhance..._instead_axis_n.html
Not sure why you would need 2 joypads the joypad has 4 axis.
Rick G
Rick G
- dab77
08 Oct 2010 18:16 #4588
by dab77
Rick G wrote:
i meant joypad-axis, so i'll need a total of three axis. ..and some button..
thanks for the link i'm going to watch it now.
i'm sorry, for my english...Not sure why you would need 2 joypads the joypad has 4 axis.
Rick G
- dab77
28 Nov 2010 21:13 #5708
by dab77
hallo, i just setup one Logitech dual pad to jog my inverted tetrapod,
and it plays not bad into joint mode.
i have a problem in world mode, since i can jog only one direction each time.
for example, if i'm jogging in x direction, as soon as i push the analog
joystick toward the y direction it stops, but without errors. than i
press again and i can jog, but always one direction each time.
is it normal?
any idea?
thanks.
is it normal?
any idea?
thanks.
Time to create page: 0.070 seconds
