HAL Pin for Coordinate System
- tom.eagan@integrisgp.com
30 Mar 2022 13:03 #238772
by tom.eagan@integrisgp.com
HAL Pin for Coordinate System was created by tom.eagan@integrisgp.com
Hello -
Is there a HAL pin available for reading the current coordinate system, G54, G55, etc?
Thanks!
Thanks!
30 Mar 2022 15:13 #238815
Replied by andypugh on topic HAL Pin for Coordinate System
I looked and could not find one. Which does not necessarily mean that it does not exist.
However, it might not actually be possible. The working coordinate system is an interpreter state, and the interpreter has generally finished the job by the time motion starts.
A possible workaround is a very small Python programme that creates a HAL pin and updates it, as the coordinate system is available in the linuxcnc.stat() object.
If that sounds like something you could do, documentation is here:
linuxcnc.org/docs/stable/html/hal/halmodule.html
and linuxcnc.org/docs/stable/html/config/python-interface.html
30 Mar 2022 16:06 #238829
Replied by tom.eagan@integrisgp.com on topic HAL Pin for Coordinate System
Thank you... that's probably more effort than I want to go to, but I'll keep it in mind...
The application is: I have a pyvcp panel that allows the user to set the coordinate system, and it stores it and retrieves it to/from linuxcnc.var #5220. But when a g-code file is run that changes the coordinate system, or the User changes it using an Axis MDI Command, the pyvcp panel doesn't doesn't know about it and is then out of sync until next restart. Just looking for an easy fix.
Thanks!
Thanks!
- MaHa
- Thank you received: 241
30 Mar 2022 17:23 #238842
by MaHa
Replied by MaHa on topic HAL Pin for Coordinate System
If you are using axis, there is this workaround to display current ucs.
www.forum.linuxcnc.org/21-axis/38824-yes...axis?start=10#164000
30 Mar 2022 17:37 #238843
I would have to learn a lot more about the ins and outs of linuxcnc to implement that, which I could do, but not sure it's worth it right now.
In addition to displaying in Axis, is it available to pyvcp?
30 Mar 2022 18:31 #238849
If you converted it to one of the others then I think that the Python handler code could poll the linuxcnc.status() and update itself.
We have rather too many VCP options (PyVCP, GladeVCP. QTVCP, QTPyVCP...) and PyVCP is the oldest and weakest.The application is: I have a pyvcp panel that allows the user to set the coordinate system,
31 Mar 2022 08:02 #238895
Thank you, I'll look into that. Thanks to all for your help.
Time to create page: 0.182 seconds
