not able to create the example userspace python component in 14.14
- vraniel
07 Apr 2022 06:00 #239527
by vraniel
not able to create the example userspace python component in 14.14 was created by vraniel
hey.
first timer with his first problem. help very appreciated
when i create a userspace component like shown in 14.14, even just copy paste, it does not create the pins, that i defined...
halcmd: loadusr test works fine and opens the script
halcmd: show pin also works, but does not return any pins.
halcmd: setp test.in 3.14 => this pin does not exist
also, if i rename the script passthrough instead of test, like suggested by the docs, halrun doesent even find the script.
dont know, what information you might need to help debugging. so please feel freee to ask!
thanks
vraniel
thanks
vraniel
- vraniel
07 Apr 2022 07:22 #239533
by vraniel
Replied by vraniel on topic not able to create the example userspace python component in 14.14
i think i solved my issue.
i thought $PATH refers to my setup folder, where all the hals and inis are.
thats why i cant open anything thats not named test. which leads me to think, there is a test.py somewhere already that i opened all the time.
sry for bothering
sry for bothering
- vraniel
08 Apr 2022 06:37 #239653
by vraniel
for those enjoying watiching a noob, struggeling with a task he well underestimated, a little update:
it works!
somehow at least.
//inside already running linuxcnc, through hal-config page:
loadusr arduthc // working flawless
show pin | grep arduino //shows all the pins with the arduino analog values attached
net net1 arduino.xxx-xxx // works fine and shows values on my gui does everything its supposed to at this point
//but:
loadusr -W arduthc // hanging up. i assume linuxcnc is waiting for the infinite loop thats polling the values from the arduino...
//inside hal file:
loadusr arduthc // working aswell
net net1 arduino.xxx-xxx // error => arduino.xxx-xxx does not exist // if i do this in hal config afterwards, it works. so i assume its a timing issue.
it works!
somehow at least.
//but:
//inside hal file:
- Thank you received: 4656
09 Apr 2022 17:17 #239779
So, are you calling the "ready" function, and does the HAL component name match? A common cause of trouble here is a component name that does not match the file name.
Replied by andypugh on topic not able to create the example userspace python component in 14.14
It is waiting (-W) for a halcomponent called "arduthc" to report readiness.loadusr -W arduthc // hanging up. i assume linuxcnc is waiting for the infinite loop
The following user(s) said Thank You: vraniel
- vraniel
11 Apr 2022 04:44 #239910
by vraniel
wow, i would have never tried that for debugging! they are indeed named differently. i will try right away when i get home. really hope thats it! thanks!
Time to create page: 0.662 seconds
