i have added a Toollengthsensor to my machine and there are some strange problems with remapping M6.
I hope someone has some ideas how to fix it or at least methods for debugging the problem.
How it´s implemented:
Gmoccapy is used and the change.ngc from Gmoccapy is added to the subroutine path.
INI-File in the RS274NGC section:
REMAP=M6 modalgroup=6 prolog=change_prolog ngc=change epilog=change_epilog
In addition i´ve modified the change.ngc and added two debugmessages.
;debugmessage previous to original M6
(debut, Test1)
M6
;debugmessage after original M6
(debug, Test2)
What´s happening:
- The debugmessage "Test1" appears
- original M6 is executed
- The debugmessage "Test2" is not shown
This is happening also with other change.ngc files (like Versers Probescreen).
At the moment I have no idea what´s (not) happening and would be very happy if somone can bring some light into the darkness
Thanks a lot!
Mic
